Need camber expert's help!
I am thinkin about lowering my car with the Tein S springs with 1.4" drop all around. I know after I install them, i will need to get an alignment to get the toe straight, but will i need a camber kit? also, will my stock struts be good with this, since it is only a 1.4" drop? thanks in advanced!
People say that if you havent lowered your car more than 2 inches you won't need the camber kit, but from what the people i've worked with said... anytime you lower a honda you need the camber kits, i'm saving up now for camber kits just to be on the safe side
after you lower your car you will just have to wait and see how it goes. It works differently for every car, so just lower it for now and keep an eye on your tires. Also when you get it aligned look at your print out and see how far off your camber it and that will give you a good idea also if you need one.
