problem w/ys1 cable tranny and xtreme pressure plate
when i first put on the 6puck and hd xtreme pressure plate, the cable was nearly impossible to put on the tranny. i finally did it but it was all the way adjusted loose and still the pedal was stiff to the top. when i went to press the cluch in, i heard something pop and the pedal loosened up a little allowing me to adjust the cluch some on the cable. when i did my motor rebuild, i noticed one of the release fork spring that one side came off of the release bearing. i put it back on and put on the tranny. upon installing the cable, the exact same thing happened. the clutch seems ok but i'm not sure what exactly what's going on. anyone had this problem. do you think it's a potential problem or am i ok?
Sinner
12
Dec 15, 2004 01:23 PM
crx1856
Sep 21, 2003 05:41 PM
