what kind of numbers on your turbo sohc
like says what kind of numbers do you put down to the wheels on your turbo single??...i just bought a Greddy kit for my D16y7 and was just curious on what kind of numbers i might expect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexSiT3 »</TD></TR><TR><TD CLASS="quote">t3 60 trim at 6psi put down 205whp at 7000rpms on my d16....</TD></TR></TABLE>
200+whp at 6psi ? I gotta see that dyno sheet....
https://honda-tech.com/zerothread?id=568754, 219 hp at ~6200 rpm, u can calculate the torque off of that
sweet those are some awesome numbers i have a D16y7 so with that GReddy kit intercooled at 5.5psi i would like to see around 145-155 to the wheels do u guys think that is to far fetched? and later on add the y8 mani and go for a little bit more power
145-155 might be a little to high of a guess for only 5.5psi
you only got about 90 to the wheels as is and i would think without the advantage of having the high lift vtec lobes a guess of about 8 hp per psi would be appropriate depending other variables like, intercooler, exhaust, tuning, etc...
so maybe closer to like 130-140 but then again you never know and with good planning of parts and really good tuning you probably could do it.
whats every one else think
see sig... was on a T3 60 trim (.60 cold/.48 hot side) on a dyno tuned afc hack. ran it at 10psi on hondata (had my friends d16 turbo maps in it) but i never dynoed though since i was selling the kit
yea my plans are to get the mini me swap ASAP but money is a factor so i will b running no vtec for a while...I have no money for tuning so i guess I will expect some pretty low numbers but it will b a hell of alot better than stock high 17 sec. car...lol
rexsti, what else do you have done to your car? 6 psi 205 whp on a sohc :-T seems a little far fetched. I was thinking about swapping the 15G for a Super 60 since they have the same bolt pattern for the manifold.
well believe it...it happened, my car weights probablly 2200lbs or so i imagine, ist a 90 crx si.... i have 8.7:1 compression, zex cam and springs, srp pistons, eagle rods, basically it..the turbo is a 60 trim t3, tial wastegate with 6psi spring, sidemount, dsm 450s and pump and afc hack with ghettodyne pulling timing..... trust me i was surprised myself, it would have been higher if i woulnt have shut down at 6800....cause it wasnt done pulling at all, but thats all for now...boost is getting turned up within the next 2 weeks so new numbers i hope are coming....lata
How bad is the lag on the super 60? I love the spool up on my 15G but the topend is not the greatest. I know alot of it is in the tuning and other variables, but what would be an aproximate increase in hp going from a 15G@15psi to a T3@15psi w/revhard manifold, I have forged internals, hondata, 3"exhaust and downpipe.
