Distributor - making rustlings sounds - rotor?
Old Sep 21, 2003 | 05:30 PM
Chemicalviper's Avatar
Default Distributor - making rustlings sounds - rotor?
Just what it says - really loud clicks that sound like the rotor is touch paper almost - not like i can take cap off and turn on car - i checked it seems fine, not touching anything. any ideas.
Old Sep 21, 2003 | 06:44 PM
bump, help?
Old Sep 22, 2003 | 03:39 AM
JimBlake's Avatar
Default Re: (Chemicalviper)
Maybe take the whole distributor off & spin it?
Old Sep 23, 2003 | 01:19 PM
anyone had this problem?
Old Sep 23, 2003 | 03:45 PM
TimoneX's Avatar
New User
I've heard several Honda distributors making this "crunching" sound for lack of a better term. My '95 GSR did this for 18 months w/o any negative effects.
Old Sep 23, 2003 | 09:32 PM
wut happened after the 18 months ... lol
Old Sep 23, 2003 | 10:57 PM
Dased530's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Maybe take the whole distributor off & spin it?</TD></TR></TABLE>
Old Sep 23, 2003 | 11:10 PM
im_the_teacher's Avatar
Default Re: (Dased530)
i had this problem on my 93 accord...
the distubitor's bearing is out....either get new bearing or get new dist. housing. for cheap ....around 100 bucks at dealer.
if problem on going w/ out fix....cause misfire and etc....and u do not want to stuck in middle of road...get it fix soon
Old Sep 23, 2003 | 11:22 PM
Thanks - by bearing you mean what the rotor is connecting too &gt;? and we are talking about like a rustling sounds right ? almost chattery.
Old Sep 24, 2003 | 04:26 AM
JimBlake's Avatar
Take the distributor off. Spin it & watch the rotor & the sensors under the rotor. Maybe one of the sensors is rubbing? The star-things on the shaft are supposed to pass close to their sensors without touching.
Otherwise look at the bearing inside the base of the distributor. It's what lets the distributor shaft spin smoothly without being loose & wobbly. Does the shaft wobble? Does it grind or anything instead of spinning smoothly?
Old Sep 25, 2003 | 09:15 AM
I get home tonight, so i will post tonight or tomorrow - thanks for help - will keep updated.
B16CRXT
Feb 14, 2007 05:35 PM
92 CIVIC HATCH VX
Apr 12, 2006 09:58 AM
Magic Wheels
Nov 18, 2005 06:45 PM
Coreyja
Oct 13, 2002 11:42 AM
