How hard is it to change out a starter??
Old Sep 21, 2003 | 04:53 PM
daewonder.'s Avatar
Default How hard is it to change out a starter??
My starter's bad and my dad's asking me how hard it is to switch it out. I wouldn't mind saving money on labor if I could but being the novice that I am I don't even know where the damn thing is. Anyone have any tutorials on this install?
Thanks in advance.
Old Sep 21, 2003 | 05:02 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How hard is it to change out a starter?? (B18Chillin)
directly under the intake pipe, the black cylinder thing sitting horizontally on top of the tranny bellhousing.
Shouldn't be too hard, just remove the intake and stuff above it to give you room to reach it.
philafelman's Avatar
not hard at all
you just take off the 12mm nut holding the thick wire on, then pull off the thin wire (it just slides on and off), then there are 2 14mm bolts that hold the starter to the transmission...take your intake off to be able to pull it outta the engine bay...and you are done. also, dont forget to disconnect neg. battery terminal.
Old Sep 21, 2003 | 05:42 PM
B2FiNiTY's Avatar
Takes 10-15 minutes only because the bottom bolt is **** hard to get to. Hurts the back bigtime.
Old Sep 21, 2003 | 10:56 PM
daewonder.'s Avatar
Default Re: How hard is it to change out a starter?? (B2FiNiTY)
right on. thanks guys. hope all goes well tomorrow.
Old Sep 22, 2003 | 03:18 PM
daewonder.'s Avatar
new question guys..
i'm missing one of the bolts that holds the starter to the tranny housing. it's the extra long one. anyone know of any onlines sites where i can get it? i called the local acura and they don't have it. i can order but i have to prepay and they're an hour from where i live so i'd rather have it shipped to me.
thanks.
Old Sep 22, 2003 | 05:31 PM
get one from honda for a dohc vtec del sol or a 99-00 civic si...same thing.
YangFlavor
Honda Civic (2001 - 2005)
Jul 27, 2009 07:18 AM
T3KNiQe
Nov 26, 2008 07:24 AM
B bOy CrAyOn
Aug 6, 2007 07:24 PM
WreckedTeggie
23
Dec 26, 2005 06:41 PM
mickey513
Mar 11, 2003 02:03 PM
