91 octane ok for high compression?
Now that the octane here in california has dropped to 91, I am concern if it will be enough for a higher compression engine. As it has been stated before, it is benefial to have higher compression when running aggressive cams (ie. toda b or toda c), but will 91 octane be sufficient for some one that lets say has TODA B's & JDM ITR PISTONS? May be some of you can tell me how can I determine how much octane is needed for the different compressions?
Thanks
Thanks
what would be considered about the max that we can go for compression?
I can have custom rods and pistons made, but I have no idea what specs to go with. Is it even worth upgrading on an otherwise stock motor (stock cams)?
yoshi - who can use some help in this area
Thats with 91 octane?
So I may be able to get away with higher compression, using 91 octane, than the JDM ITR PISTONS. May be the CTR's?
SGT: you mentioned you are running the CTR pistons on 92 octane with out any problems. Would the 1 octane difference give me any problems? I may consider the CTR pistons.
According to this, https://honda-tech.com/zerothread?id=61228
The ITR pistons are 11.1. Some said the CTR pistons were 12.2 or 12.5 & http://tiiite.b16a.com/pistons.htm said the CTR pistons are 11.6 or more.
Has to do with emmision standards for CA. I think it was H-T member dustin that had posted this link recently:
http://rely.net/~dustin/fueloctane.html
How high of compression can one run with no mods to the OE ECU, retaining 16 deg timing, on 92+ octane, and remain "ping" free during Southern summers?
I would have to say 11.8:1~12.3:1 would be safe ...but it also depends on pistion prep to less sharp edges in the combustion area the less likely it will ping...But then again what do I know
pumpkyn
19
Aug 17, 2006 09:24 PM
Mad Cow Disease
May 20, 2004 11:30 AM
