Help!!! 1st Gear and 5th Gear grinds
Old Sep 21, 2003 | 11:30 AM
N1NjA TuRtLE's Avatar
Default Help!!! 1st Gear and 5th Gear grinds
I now drive my bro's 4 door GSR. He resently replaced a new clutch, but when u put it into 1st it grinds, it can go into 1st geaar but grinds, also his 5th gear grinds also. Some people are telling me it's the synchros. But what else can be wrong? and how much would it cost to fix this?
Old Sep 21, 2003 | 11:32 AM
Default Re: Help!!! 1st Gear and 5th Gear grinds (YellowSpoonEG6)
ttt
Old Sep 21, 2003 | 11:37 AM
anyone?
Old Sep 21, 2003 | 11:38 AM
TarHeeLgsr's Avatar
its teh sychros to 1st and 5th gear
Old Sep 21, 2003 | 11:40 AM
Default Re: (TarHeeLgsr)
how mcuh would it cost to fix?
Old Sep 21, 2003 | 12:10 PM
thrty8street's Avatar
why not just get a new tranny? i don think there more than 700 dollas.
Old Sep 21, 2003 | 01:43 PM
Default Re: (thrty8street)
anyone else have any ideaS?
Old Sep 21, 2003 | 01:48 PM
wall of tvs's Avatar
Default Re: (YellowSpoonEG6)
Try changing out the tranny fluid first -- I would recommend some Honda Synthetic MTF.
If that doesn't work, you're s.o.l...
Old Sep 21, 2003 | 01:59 PM
Ph0eNix's Avatar
Default Re: (wall of tvs)
Try changing your tranny fluid...if it still grinds then your 1st and 5th syncros needs replacement.
Old Sep 21, 2003 | 03:44 PM
B2FiNiTY's Avatar
High rpm only? If so, syncros.
If it's at all rpms and speed, then it could be osmething else.
Old Sep 21, 2003 | 03:49 PM
01-1293's Avatar
Default Re: Help!!! 1st Gear and 5th Gear grinds (B2FiNiTY)
try changing out your tranny fluid to GM syncromesh........might as well try a cheap potential solution first
Old Sep 21, 2003 | 05:08 PM
NeoGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">High rpm only? If so, syncros.
If it's at all rpms and speed, then it could be osmething else.</TD></TR></TABLE>
exactly.....high RPMs usually denote bad syncros......at all RPMs, possible a clutch/ clutch related problem
Old Sep 21, 2003 | 08:37 PM
Default Re: Help!!! 1st Gear and 5th Gear grinds (NeoGSR)
nope , not at all at high rpms. just regular everyday driving dude. Say i reverse my car in the morning and then i throw it to first it'll grind but it'll still force itself to go in gear like normal, it's just that there's a grind in between, and with 2nd,3rd and 4th gear it's oaky, then when i go to 5th it grinds again. not at all at RPMS just damn regular daily driving. So yea, is it still the synchros or maybe something else?
Old Sep 21, 2003 | 09:20 PM
bizzump need more input.
Old Sep 21, 2003 | 09:34 PM
RedLinin247
Guest
Posts: n/a
i agree with the above, synchro's.
Old Sep 21, 2003 | 09:35 PM
hndarcrb18c1's Avatar
If your looking for a cheap fix My trans did the same thing we took it apart took out the syncros and filed the burrs off the edges shifts like butter now.....
Old Sep 21, 2003 | 10:07 PM
Default Re: Help!!! 1st Gear and 5th Gear grinds (hndarcrb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hndarcrb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">If your looking for a cheap fix My trans did the same thing we took it apart took out the syncros and filed the burrs off the edges shifts like butter now.....</TD></TR></TABLE>
heh, if only i was that knowledgeable....
Old Sep 21, 2003 | 10:18 PM
bump
Old Sep 22, 2003 | 12:04 PM
NeoGSR's Avatar
i think it's the clutch if it's everyday driving.....maybe a spring broke or something....just my .02.....
indtegra
Nov 5, 2007 07:22 AM
blackdelslo
Sep 10, 2004 08:19 PM
TrueDC2
Oct 3, 2003 12:13 PM
i HAVEtheADVANtage
17
May 28, 2003 10:58 PM
