tips on painting "trim" on lexan windows???
Old Sep 21, 2003 | 11:15 AM
DaveF's Avatar
Default tips on painting "trim" on lexan windows???
ok, just wondering if anyone has any tips on painting the black "edge" on lexan windows to make them look more like stock.
any particular paint i should use?
anything that you wouldnt recomend???
thanks guys.
Old Sep 21, 2003 | 11:35 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: tips on painting "trim" on lexan windows??? (2.2Lcivic)
use some rc car paint. it adheres tp plastic better.i used to use regular flat black when i was doing car stereo installs and it worked just fine
Old Sep 21, 2003 | 12:01 PM
Rboosted717's Avatar
any good black paint will work for the most part (I've used primer, gloss, semi-gloss, etc... you name it). You just have to prep the surface good. I would recommend scuffing the area your going to paint with some steel wool or a med/fine grit sand paper to prevent peeling, chipping, etc...
I would also recommend to do all you cutting, shaping, and drilling before painting. Also a few coats might be needed to give a good black finish. If your really ****, once paint dry's place the lexan against the car to see if the black is transparent. On light colored cars, etc... you need a few coats because the white paint may show through the black painted lexan.
Old Sep 21, 2003 | 12:39 PM
quickda6's Avatar
Default Re: tips on painting "trim" on lexan windows??? (Rboosted717)
dave, i have the fal rear windows, and if im not mistaken it isnt paint they use. some kind of vinyl like material....ill check it out for ya!
Old Sep 21, 2003 | 01:04 PM
DaveF's Avatar
Default Re: tips on painting "trim" on lexan windows??? (quickda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quickda6 &raquo;</TD></TR><TR><TD CLASS="quote">dave, i have the fal rear windows, and if im not mistaken it isnt paint they use. some kind of vinyl like material....ill check it out for ya!</TD></TR></TABLE>
i was thinking about doing something to that extent, like get a piece of vinal cut out to the fatory "black edge" specs, but than i remebered about painting the inside of my RC cars back in the day.
tell me what you think.
if i decide on painting, how would one sugest i tape/ block off area's i dont want to paint.????
i was thinking about appling some of the "blue" masking tape to a piece of wax paper(so i can re apply to my lexan) and trying to trace over a stock window thus giving me the proper "area of black" than cut it out, peel it off the wax paper, apply it to my lexan, paint(maybe a few times) than peel the blue masking tape off my lexan.
thanks again
Old Sep 21, 2003 | 01:05 PM
speedworks's Avatar
just tape off the back side, use 1000 grit sand paper and scuff the surface, then use krylon semi-flat black. three light coats will easily cover it.
Old Sep 21, 2003 | 02:27 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: tips on painting "trim" on lexan windows??? (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">just tape off the back side, use 1000 grit sand paper and scuff the surface, then use krylon semi-flat black. three light coats will easily cover it. </TD></TR></TABLE>
----Yeah, just make sure the lexan is scuffed, other then that, the paint would have to be pretty bad quality, Lik Kevin said, 3 coats and you should be good for a while. Make sure all the holes are cut before paint.
Old Sep 21, 2003 | 03:39 PM
evil93evo's Avatar
if your windows still have the protective coating, just mark off what I want painted, cut it along the line you drew with a razor going lightly.
Then prep the area, paint it black. You dont have to mess with masking anything else.
I always have to make my windows from a sheet so.... I comes with the paper on both sides.
Tom
Old Sep 21, 2003 | 04:04 PM
25 Year Member
Default Re: (evil93evo)
just do as evil; says and cut the protective paper where you want it painted and use RC paint.the only prep you need to do is clean it.if you are just pealing off the paper,it will already be clean.do not sand it,the sanding might show up in the lexan.just mask it off and paint it. i have done this thousands of times in car stereo installs and never had a problem.
Old Sep 21, 2003 | 04:09 PM
1fstcorrado's Avatar
yep cut your window and drill out then trace out where you want to cut on the lexan protective cover, then paint.....or if you dont want paint you could cover the entire window with black vinyl and trace out...dont know how well it would work.....make sure you put some type of thin weather seal or sealant on your window....because if it gets caught in the rain it will get in there....
Old Sep 21, 2003 | 04:16 PM
DaveF's Avatar
Default Re: (1fstcorrado)
turbotyper and 1fstcorrado, thanks for the insight. i think im going to go with this "route" ...ill see if i can post up some pics when i finish the task. thanks guys.
Old Sep 21, 2003 | 07:21 PM
wHOAlly's Avatar
Default Re: (2.2Lcivic)
teh rc paint they speak of is called PACTRA its designed for polycarbonate, which is what lexan is made of
Old Sep 22, 2003 | 07:13 AM
DaveF's Avatar
Default Re: (Sp00n'd Supra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sp00n'd Supra &raquo;</TD></TR><TR><TD CLASS="quote">teh rc paint they speak of is called PACTRA its designed for polycarbonate, which is what lexan is made of</TD></TR></TABLE>
thanks, ill keep this in mind. ...
i should be able to find this at my local "hobie shop" correct??
Old Sep 22, 2003 | 07:22 AM
Fabman's Avatar
Lierley Fab
you can get the paint for that from jerry bickel 636 356 4727....whats up with your part that ron is fabing????
Old Sep 22, 2003 | 07:40 AM
DaveF's Avatar
Default Re: (fabman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabman &raquo;</TD></TR><TR><TD CLASS="quote">you can get the paint for that from jerry bickel 636 356 4727....whats up with your part that ron is fabing????</TD></TR></TABLE>
id love to know the same ****..ron keeps talking like he is gonna get our **** out to us but i have yet to see it. im really getting sick of it..he claims he doesnt have the equipment to do the job any longer. i think he is taking me and a few others for a ride......(take the money and run)..
im gonna have my car running in about a month or so, and rons parts will still not be on my car....so ill have a running car with no front suspension. how effective.
Old Sep 22, 2003 | 08:47 AM
Fabman's Avatar
Lierley Fab
have him drop thr stuff of at rob moores if ther is some welding or fab work i will do it for free to help out so you can get that car going
Old Sep 22, 2003 | 08:55 AM
bambooluv's Avatar
I hope that goes for the both of us. Ill let ron know.-pete
Old Sep 22, 2003 | 09:51 AM
DaveF's Avatar
Default Re: tips on painting "trim" on lexan windows??? (bambooluv)
thanks fabman!!
im going to give ron a call and see whats up.
thanks again.
dave
Old Sep 22, 2003 | 10:15 AM
earl's Avatar
There is 2 types of lexan..regular and scratch/mar resistant. For painting the regular, cut off the backing like others have said. Spray some carb cleaner on a rag and just wipe it over the exposed area. You can then use any cheap paint after that and it will stick perfectly.
As to the scratch resistant, this will not work as paint will pop off in spots. Next time I will try the RC paint idea. Good idea
Old Sep 22, 2003 | 10:31 AM
Juan Q...'s Avatar
Default Re: tips on painting "trim" on lexan windows??? (earl)
Flat black RC car paint looks the best on mr10/scratch resistant LEXAN.
Old Sep 22, 2003 | 04:17 PM
Fabman's Avatar
Lierley Fab
yes you to bambooluv
Old Sep 23, 2003 | 01:54 PM
speedworks's Avatar
Default Re: tips on painting "trim" on lexan windows??? (fabman)
if you do not sand it, it will not stick. 1000 grit will not show scratches.
Old Sep 23, 2003 | 01:57 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">if you do not sand it, it will not stick. 1000 grit will not show scratches.</TD></TR></TABLE>
thanks for the tip
Old Sep 23, 2003 | 03:15 PM
L-B racing's Avatar
we just cut the windows and put them in then used the car to trace the pattern and pull off the inside piece and your done. it looks very clean. if you plan on keeping the car for a while. paint always seems to start to look nasty and gets spotty after a while. weve had vinyl on our windows for 2 1/2 yrs and it still looks new(the vinyl anyways)
MilanoCivic97
Mar 9, 2007 10:14 PM
loizenin
Oct 24, 2006 02:44 PM
dan_w_82
Feb 13, 2005 08:44 PM
The Alchemist...
Aug 7, 2003 03:27 PM
