would too big of a battery make my battery keep dieing?
Old Sep 21, 2003 | 04:07 AM
civictypenos's Avatar
Default would too big of a battery make my battery keep dieing?
i have a huge battery,and it dies on me super fast(after sitting for about 3 days),i cant think of anything that would drain it over night.
i know its almost twice the size of the stock battery.could my alternator maybe not be charging it fully because its so big?
Modified by civictypenos at 10:30 AM 9/21/2003
Old Sep 21, 2003 | 06:30 AM
Default Re: would too big of a battery make my battery keep dieing? (civictypenos)
Old Sep 21, 2003 | 09:49 AM
PetroGuyX's Avatar
what kinda battery is it?
Old Sep 21, 2003 | 10:20 AM
Default Re: (PetroGuyX)
one i bought from advance auto parts,brand new.
looking at the stock #'s and the bigger battery #'s
stock is:
ca 545
cca 435
reserve capasity is 70
bigger battery is:
ca 810
cca 650
reserve capcity is 110
i know that the cca is cranking amps,dont know what ca is and what resevre capacity has to do with anything.
Old Sep 21, 2003 | 10:45 AM
PetroGuyX's Avatar
i think you have a different problem, i don't think too big of a battery can hurt you, i may be wrong though
Old Sep 21, 2003 | 12:02 PM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">i have a huge battery,and it dies on me super fast(after sitting for about 3 days),i cant think of anything that would drain it over night.
i know its almost twice the size of the stock battery.could my alternator maybe not be charging it fully because its so big?Modified by civictypenos at 10:30 AM 9/21/2003</TD></TR></TABLE>
No, something else is wrong. Either you have a constant drain or you alternator is toast.
Old Sep 21, 2003 | 12:12 PM
ATF Kuk's Avatar
Default Re: would too big of a battery make my battery keep dieing? (nsxxtreme)
i agree. probably both. something is probably draining the battery and in the process, ur alternator went dead. or maybe its just ur alternator and it doesnt charge. wut kind of electronic upgrades do u have?
Old Sep 21, 2003 | 12:57 PM
Default Re: would too big of a battery make my battery keep dieing? (ATF Kuk)
full set up:
b16 alt
relocated big battery to the rear
4 gauge from front to rear
4 gauge ,18 inch ground
aem pulley&lt;----could be a problem???
stereo and power pulling:
zapco 650 6 channel amp
alpine cva 1005
alpine 12 disc
aline 510 surround sound
alarm with tons of upgrades(proximity,windows,scanner)
power windows
car running @ 1500 rpms ,my volts are 14.8.
Old Sep 21, 2003 | 01:54 PM
tegmech's Avatar
make sure it is a good battery. sometimes when you buy new batt. they have a bad cell in them. Take it and have it tested.
Old Sep 21, 2003 | 03:20 PM
t0p_sh0tta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictypenos &raquo;</TD></TR><TR><TD CLASS="quote">full set up:
b16 alt
1. get rid of the pulley.
2. I thought that 0 awg was supposed to be used for relocating the battery? Shouldn't it be 14v at idle?
Old Sep 21, 2003 | 03:27 PM
vteg's Avatar
New User
Default Re: would too big of a battery make my battery keep dieing? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">
2. I thought that 0 awg was supposed to be used for relocating the battery? Shouldn't it be 14v at idle?</TD></TR></TABLE>
1. That is what I recommended in his other post. The problems are obviously related.
2. On a honda 4 cylinder, you can get away with 4 gauge IMO. At 400 amps the voltage drop would be 1.68. But 400 amps can crank a v8. A 4 cylinder starter is closer to 200-250 amps which gives 1 volt drop. Calculations assume a 16.5 foot run of cable. It should be shorter than that.
hatcht9x
45
Jan 12, 2009 10:00 PM
dog the bounty hunter
Feb 5, 2006 11:50 AM
Boxcar
Audio / Security / Video
16
May 1, 2005 12:54 AM
BlackThorN
15
Jun 27, 2004 01:31 PM
