my cars leaking alot of gas under passngerside rear..
Old Sep 20, 2003 | 08:50 PM
CityHunt3r's Avatar
Default my cars leaking alot of gas under passngerside rear..
it leaks alot alot after i drive around in it.. then stops after my car comes to a stop.. can anyone suggest anything.. i cant see and of the fuel lines without taking off the tank but im not sure i wanna get into all that ... anyone happen to know how much gan tanks cost???
Old Sep 20, 2003 | 08:55 PM
CaptainObvious's Avatar
Default Re: my cars leaking alot of gas under passngerside rear.. (CityHunt3r)
Im not sure of the cost but im willing to bet it will be a sound investment...in your future none the less. Sounds like there is a small hole in the front if it leaks when you stop.
Old Sep 20, 2003 | 09:20 PM
Stripped Honda's Avatar
99-0104
Default Re: my cars leaking alot of gas under passngerside rear.. (CaptainObvious)
check the hoses there are a few hoses that can leak under there
Old Sep 22, 2003 | 06:36 AM
CityHunt3r's Avatar
thanks for replies but i figured it out.. my gas tanks leaking ima replace it. for the firs time... .... anyone have any insight to what lines are what and any prcautions i should take????
Old Sep 28, 2003 | 03:34 AM
Confuc1ous's Avatar
dont smoke
Old Sep 28, 2003 | 05:50 AM
NathanMorris's Avatar
Default Re: my cars leaking alot of gas under passngerside rear.. (Confuc1ous)
it'd help if the gas tank is somewhat empty....so if you're going to replace it anyway, and the tank is almost empty, you may descide to drain the tank before pulling it off. Move the gas tank far far away from anything flamable......and away from you and anything you would mind to lose . It's not that volitile of a chemical if treated with respect, but you just need to be really careful...gasoline vapor is what'll explode so be really gentle with that.
Good luck,
Nathan
Old Oct 8, 2003 | 07:14 PM
CityHunt3r's Avatar
I DID IT!!!!!! it was hard fititng my pump n gauge into the new tank but i didt it!!!
Old Oct 9, 2003 | 04:39 AM
StimpyBoy's Avatar
Default Re: (CityHunt3r)
Good job!
Now you're ready to try your hand at the crank pulley bolt or some other equally unsavoury task
k20eklipse
13
Dec 6, 2010 07:43 AM
kingrukus
Aug 25, 2010 02:32 PM
higgunscrx
Feb 25, 2007 06:31 PM
da_33
Oct 26, 2006 08:45 PM
jspek29
12
Mar 23, 2004 04:28 PM
