need help my antenna wire is cut....
when they stole the headunit they cut everything meaning the harness for the headunit also the antenna wire my question is what is the best way to reconnect the antenna wire up so it can still recieve clear radio station????
What kind of car? It is possible to splice the cut end with another wire with a plug on it. If you need to do it quickly until you replace the antenna and wire, you can strip back the wires, exposing the outer braid and center conductor. Splice the center wire together and solder, then insulate with tape. Then, twist the braid together, and solder, then tape. Ghetto, but should work until you can replace everything..
Sorry about the thievery you experienced though...
yeah i hate thiefs y cant they just leave the harness alone and just take the damn headunit but anyways yea i was thinking of just splice the wire up and also what you guys think about a internal antenna ???? cuz i hate my stock one just come all the way up on my civic look nasty!
koumatae
Aug 2, 2012 12:53 PM
