Necessary parts for OBD0 to OBD1 Conversion
Old Sep 20, 2003 | 02:18 PM
Norcalstoppy's Avatar
Default Necessary parts for OBD0 to OBD1 Conversion
If I wanted to convert to OBD1 from OBD0 WITHOUT using the conversion harness, what would I need exactly other stuff listed below.
1)Complete OBD1 harness
2)OBD1 distributor
3)OBD1 ECU
4)OBD1 Injectors
Jay Kim
Old Sep 20, 2003 | 03:00 PM
PHiZ's Avatar
Default Re: Necessary parts for OBD0 to OBD1 Conversion (Dentilicious)
You still need a conversion harness
You can use the OBD1 engine harness. I think you can get away with using obd0 injectors, just remove the resistor box from the circuit. However you would need to change the injector plug types.
You COULD change the chassis harness, but that is a lot more time/effort/money than just getting an ecu conversion harness.
-PHiZ
Old Sep 20, 2003 | 05:45 PM
turbod96ex's Avatar
I think this guy has real cheap harness conversions for this. like a 150 shipped. Might be cheaper and deffinately would be easier than getting all that other stuff.
Just look on ebay under harnesses.
slickrickauto
Texas -OK -LA (Sales)
Aug 9, 2008 06:36 PM
bobbyisking
Jul 7, 2008 09:22 AM
jisu009
Mar 26, 2004 01:13 PM
88da3
Nov 13, 2003 01:12 PM
