People wth Toda B's
Anyone with this setup or a similar setup what should I expect to run in the 1/4 mile. I am hoping for approx. 190 whp
2001 Type R
Toda Spec B cams
Toda valve springs
Portflow Ti retainers
Toda cam gears
Spoon 4-1 Header
Carsound cat
VAFC
AEM intake
Tuning Tuning Tuning
Best time so far 14.71 @95 -just AEM intake
2001 Type R
Toda Spec B cams
Toda valve springs
Toda cam gears
Spoon 4-1 Header
Carsound cat
VAFC
AEM intake
You will be in the 185-190ish range, with the factory brakes and street tyres, you'll hit 13.6,7,8,9 @ a little over 100mph with the right tuning.
[Modified by B18CXr, 9:41 AM 8/23/2001]
I'd add an aftermarket exhaust to your list of mods if you don't already own one. The OE cat-back has several significant bottlenecks in it that will impede flow.
Question regarding the MIL (Malfunction Indicator Light - according to Helms
) or the CEL as y'all say...
Do the chaps with the PowerFC (Austin?) see the MIL at all times, too? Or is that a consequence of running the OEM ECU with a VAFC piggy-back?
) or the CEL as y'all say...Do the chaps with the PowerFC (Austin?) see the MIL at all times, too? Or is that a consequence of running the OEM ECU with a VAFC piggy-back?
i'm always hesitant to run my car hard with the check engine light. it will probably go into limp mode. which isnt' healthy for the car.
About the CEL, well the PowerFC does not trigger the CEL unless something is seriously wrong, it is an OBD I ecu, so there are quite a few little things that are not used by the ECU, you can also go with a Hondata, or purchase a preprogrammed "generic" TODA B ECU like the ones that Dan at Godspeed sells, there are a few others that sell it also, but if you have the option to purchase a programable one you will not be unhappy with the future flexibility.
Austin
So fishy... I don't think I could stand that light winking at me... and taping it/removing the bulb isn't an option (it's kinda like setting your clock 15 minutes fast so you're not late to work...)
PowerFC looks like a real winner... except that knock/timing retard thing mentioned elsewhere...
Can someone please answer the original question....and stop ranting on and on and the cel. Anyone with this setup, what are you 1/4 mile times.
Austin
I am not just looking for 1/4 mile cams....I am mainly looking for some more low to mid range torque...I can't stand the wait to get to vtec...especially in first gear. That is my only complaint about my car, so I am trying to fix it. Thanks for all your info it is very helpful...you guys know your **** about the R
Drinker
