N/A means ?
Old Sep 20, 2003 | 08:48 AM
ddua's Avatar
Default N/A means ?
I am sorry if this is a noob question but I just want to verified this,
is N/A same as All Motor ? and what OEM stand for ?
Old Sep 20, 2003 | 08:58 AM
Kavehman's Avatar
Default Re: N/A means ? (ddua)
N/A stands for Naturally Aspirated
OEM is Original equipment from Manufacturer
Old Sep 20, 2003 | 09:24 AM
fluxion's Avatar
amin n'rangwa edanea
Default Re: N/A means ? (Kavehman)
and yah it's the same as all motor
Old Sep 20, 2003 | 09:27 AM
Razor's Avatar
j/k
Old Sep 20, 2003 | 12:29 PM
ddua's Avatar
so which one would cost more $$$ N/A or turbo in general for the same amount of
HP ?
Old Sep 20, 2003 | 12:50 PM
fluxion's Avatar
depends how much hp you want.
Old Sep 20, 2003 | 02:06 PM
Jaysun's Avatar
Default Re: N/A means ? (fluxion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluxion &raquo;</TD></TR><TR><TD CLASS="quote">depends how much hp you want.</TD></TR></TABLE>
Beat me to it...
Old Sep 20, 2003 | 02:40 PM
ddua's Avatar
hmmm... let's say around 250 HP
Old Sep 20, 2003 | 04:03 PM
kentucky accord's Avatar
N/A means Not Applicable
Old Sep 20, 2003 | 07:32 PM
93accordEX's Avatar
in that case na
Old Sep 20, 2003 | 09:18 PM
Jaysun's Avatar
Default Re: N/A means ? (93accordEX)
cheaper to get 250hp na? 4real? I woulda thought turbo....
Old Sep 20, 2003 | 09:34 PM
93accordEX's Avatar
Default Re: N/A means ? (QuikJaysun)
he said which would cost more
Old Sep 20, 2003 | 09:39 PM
Jaysun's Avatar
ok whew, for a sec i thought my whole ideas on na/turbo hp prospects were jacked...
Old Sep 20, 2003 | 11:09 PM
KTeller8's Avatar
NA vs FI can be talked all day long
its a matter of what you want. some say boost or Nawwwwss is cheating and they want all motor and only motor!! nothing else!
some dont care as long as they get a number
its like you want HP or fast times?
E.T vs HP #
Old Sep 21, 2003 | 09:39 AM
twkdCD595's Avatar
Default Re: (KTeller8)
either way you got to pay to play... get use to it.
na is expensive and so is fi... everything is expensive.
Old Sep 21, 2003 | 10:27 AM
fluxion's Avatar
Default Re: (twkdCD595)
Old Sep 21, 2003 | 06:02 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">either way you got to pay to play... get use to it.
na is expensive and so is fi... everything is expensive.</TD></TR></TABLE>
right on..nothing is cheap..dont even think a greddy turbo or simple h22 swap would do..speed is expensive, more torque is more expensive..you start making power and then you want some more..it just never end ..it's money pit
Old Sep 21, 2003 | 09:03 PM
booja's Avatar
250hp is hard to reach all motor... probably not even possible for an f22. h22 ive seen some pretty close... for that i say turbo.
i reached 225hp at 6psi. and i got the turbo setup and everything for less than $1500
Old Sep 21, 2003 | 10:00 PM
ddua's Avatar
Default Re: (booja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booja &raquo;</TD></TR><TR><TD CLASS="quote">250hp is hard to reach all motor... probably not even possible for an f22. h22 ive seen some pretty close... for that i say turbo.
i reached 225hp at 6psi. and i got the turbo setup and everything for less than $1500</TD></TR></TABLE>
wow less than $1500.. that is cheap
what turbo set up u use?
Old Sep 23, 2003 | 09:51 AM
MadPJ7's Avatar
Not Affordable (if you do things right, or especially if you do things right, but not the first time...)
Bisi Ezerioha uses an NA F22 in his setup, which is the fastest in the world and almost breaking into the 9's. Last time I saw written figures, he made 363 HP and 227 TQ, and said on the forums here that it's easier to produce that kind of power from the F-series than an H22. Not that it's my place to post about his setup (Sorry Bisi), but THAT is very respectable.
Old Sep 23, 2003 | 09:54 AM
iam7head's Avatar
Default Re: (booja)
225 with h22 na is very possilble
225-250 whp that is
Old Sep 23, 2003 | 09:55 AM
KTeller8's Avatar
Default Re: (MadPJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadPJ7 &raquo;</TD></TR><TR><TD CLASS="quote"> Not that it's my place to post about his setup (Sorry Bisi), but THAT is very respectable.</TD></TR></TABLE>
and very expensive.. these race car drives and other ppl have some kind of sponsorship and they have ppl tearing down motors all the time
iam7head's Avatar
Default Re: (ddua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddua &raquo;</TD></TR><TR><TD CLASS="quote">
what turbo set up u use?</TD></TR></TABLE>
just about the same price for a t3t04 custom made
Old Sep 23, 2003 | 01:51 PM
NathanMorris's Avatar
Default Re: (tang.fung)
250hp from anything other than say a H22 ....all motor, would be rediculous to drive around town as the power band would be way too high. Well, it'd be kind of like an s2000....absolutely no fun to drive unless you rev it up really good.
The h22 you could probably squeaze 250hp from w/o having a boring ride around town, and of course the V6s could probably do it.
The best way to get 250hp from a four cylinder is going to be a "somewhat lightweight" turbo, supercharger ....or of course nitrous.
Building a 150hp 4 cylinder to run 225-250hp is going to require a little more than just money, unless you just want to have someone else do all the building/research for you *shrug*
- Nathan
blade0313
19
Jul 17, 2007 11:42 AM
mortificationrock
35
Apr 21, 2007 02:23 PM
igo4bmx
Jan 8, 2005 09:32 PM
BiG DaDDy O
13
Sep 23, 2004 04:23 PM
red95integ
Sep 11, 2004 08:53 AM
