bushings
Old Sep 20, 2003 | 08:31 AM
fathergoose's Avatar
Default bushings
is there a way to replace trailing arm bushings without an hydrolic press?
Old Sep 20, 2003 | 09:35 AM
Default Re: bushings (fathergoose)
ne1???
Old Sep 20, 2003 | 10:13 AM
pro1342's Avatar
Depends on what you are putting in. If you use the ES bushings, you only have to remove the rubber, or if you are using Mugen....you have to press them in.
Old Sep 20, 2003 | 10:28 AM
R6Elmo's Avatar
Default Re: bushings (pro1342)
It's not getting in the bushings that's too hard, it's getting the old rust infested old ones out. You can bring it to a shop and they'll press it out for you. Or you could get a troch, and big frigging hammer. Search "bushings"
Old Sep 20, 2003 | 11:28 AM
piscorpio's Avatar
When I needed to get my LCA bushings replaced, one was burned and hammered out, but it is really a whole lot easier to have them pressed in/out. Especially if they are stock Honda bearings or Mugen. If it is ES or similar polyurethane bushings, you can usually just push them in yourself.
thenext
Oct 18, 2011 02:12 PM
speed_demon018
Jan 14, 2009 06:55 PM
killercrx91
15
Dec 13, 2008 08:59 AM
R.S.
Feb 28, 2004 03:34 PM
The Internet Tough Guy
Oct 25, 2003 07:47 PM
