a bumpstop question on my spring/shock combo.
Old Sep 20, 2003 | 01:58 AM
LillDragun's Avatar
Default a bumpstop question on my spring/shock combo.
i have the tokico illuminas and eibach prokits on my car right now. the rear shocks came with a bumpstop that was about 1.5 inches thick. i just used that one. i didn't use the stock one. i just read that some people cut the stock ones in half and put then on there, but does that mean that i need to put the 1/2 stock and the one that came with the tokico illuminas? also in the front i just used the stock bumpstops that were already on my car. do i really need to take them out and cut them??
note:i already searched and didn't get the answer i wanted.
Old Sep 20, 2003 | 12:40 PM
LillDragun's Avatar
Default Re: a bumpstop question on my spring/shock combo. (LillDragun)
ttt
Old Sep 20, 2003 | 01:08 PM
inspyral's Avatar
If the damper did not come with its own bumpstop and you're installing lowering springs, then yes, cut the stock bumpstops in half and use the larger(wider) end. If the dampers came with bumpstops(like the Tokico rears usually do) then just use those and toss the stock ones.
Old Sep 20, 2003 | 01:17 PM
LillDragun's Avatar
Default Re: (inspyral)
ok thanx.
deviant1
Jul 12, 2007 10:11 PM
CRISIS
Suspension & Brakes
Jun 11, 2006 08:47 PM
zeroz
Suspension & Brakes
Jan 6, 2006 03:27 PM
LatinSiRacer00
May 17, 2004 09:46 AM
IntEGNYC
Oct 10, 2003 03:10 AM
