strippped spark plug hole -- can I fix it with the head on???
Old Sep 20, 2003 | 01:15 AM
e_r_i_c_'s Avatar
Default strippped spark plug hole -- can I fix it with the head on???
one of my plugs rattled loose and shot out today and I can't get a new one to thread in... I assume that it tore the last couple threads, but the hole is too deep to see (1990 accord 2.2L). I was going to try to cut in with a tap but i wondered if shavings would get into the cylinder... Any suggestions on a fix would be really appreciated, Thanks.
Old Sep 20, 2003 | 02:19 AM
bill-71SS's Avatar
Default Re: strippped spark plug hole -- can I fix it with the head on??? (e_r_i_c_)
use a lot of wheel bearing grease on the tap so the shavings will stick to it
Old Sep 20, 2003 | 06:21 AM
AngryTroll's Avatar
Default Re: strippped spark plug hole -- can I fix it with the head on??? (bill-71SS)
That is a great idea, Bill. I cannot believe I did not think of it before.
e_r_i_c_
If a few shavings fall into the cylinder, I would not worry too much about it. You can blow the cylinder out with compressed air and you can crank the engine with the spark plug out. If you do this, most of the shavings will blow out the spark plug hole. After all, it is just aluminum.
Be careful when you tap the hole. You could easily damage the threads beyond repair with a tap (if you do it wrong). A Heli-Coil kit for spark plugs will set you back about $180.00 and it is easy to screw this up, too.
Old Sep 20, 2003 | 06:25 AM
carolinaACCORD's Avatar
Default Re: strippped spark plug hole -- can I fix it with the head on??? (AngryTroll)
you can either use the grease like bill said, or rub the tap over a magnet a few times to get it magnetized, then the shavings will cling to the tap.
Old Sep 20, 2003 | 10:51 AM
iam7head's Avatar
ah...cut the fuel by pulling the ecm fuse, take out all the spark plugs, crank it with the gas panel down the floor, just like how you do a compression test, see if that will blow all the little metal shaving out.
Old Sep 20, 2003 | 08:01 PM
mwkirchner's Avatar
Default Re: strippped spark plug hole -- can I fix it with the head on??? (carolinaACCORD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carolinaACCORD &raquo;</TD></TR><TR><TD CLASS="quote">you can either use the grease like bill said, or rub the tap over a magnet a few times to get it magnetized, then the shavings will cling to the tap.</TD></TR></TABLE>
Shavings from an ALUMINUM head will cling to the magnet?
spolkyc
Engine Machining & Assembly
Jun 9, 2019 09:01 PM
RecklessEJ
Apr 30, 2012 08:13 PM
john457
Mar 12, 2007 06:03 PM
ColdBlood808
Nov 13, 2005 09:14 AM
auto_destroyer
Aug 10, 2002 08:36 PM
