Any other modifications if installing ITR or skunk2 cams?
Guest
Posts: n/a
itr and skunk stage 1's will be fine on stock gsr valvetrain just as long as you don't go over the redline, as for skunk 2's and 3's, you would definetely need upgrade valvetrain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon »</TD></TR><TR><TD CLASS="quote">
might as well get cam gears too.</TD></TR></TABLE>
Then hit the dyno and get your car tuned. If you want to maximize the potential that the cams have you should definately get tuned. Im guessing you know you have to do a valve adjustment too once you swap the cams. And possibly have to replace the gasket under the valve cover. Make sure you have someone who knows what they are doing. The number 1 reason why cams break, snap or whatever is the person doing the install. Make sure you have someone that knows exactly what they are doing because one little mistake is going to be a pain in your ***. I went to a honda technician (25 years experience). Its not very hard to do but its worth the extra money to make sure its done perfect.
might as well get cam gears too.</TD></TR></TABLE>Then hit the dyno and get your car tuned. If you want to maximize the potential that the cams have you should definately get tuned. Im guessing you know you have to do a valve adjustment too once you swap the cams. And possibly have to replace the gasket under the valve cover. Make sure you have someone who knows what they are doing. The number 1 reason why cams break, snap or whatever is the person doing the install. Make sure you have someone that knows exactly what they are doing because one little mistake is going to be a pain in your ***. I went to a honda technician (25 years experience). Its not very hard to do but its worth the extra money to make sure its done perfect.
yea i would get springs and retainers just to be safe skunk2's have 8 deg. more duration than stock and will eventually wear your stuff down. but thats just me
JdMWoRm2
27
Feb 2, 2007 01:44 AM
ALLMOTOR18
May 11, 2004 03:50 PM
rocco
33
Feb 16, 2004 01:14 PM
