some B20 questions...
Old Aug 22, 2001 | 10:06 PM
xJ.SLOTHx's Avatar
Default some B20 questions...
im looking at doing a crvtec setup, and i pretty much have it locked. heres what my setup is pretty much going to be like. what do you guys think the HP/TQ figures will be.thanks.
B16a Head w/ port and polish
Jun Stage 3 Cams w/ valve springs, retainers
ITR intake manifold
Over Bored TB
RC 270cc injectors w/ fuel regulator
AEM Cold Air Intake
B20 block
ARP Stud Bolts
Eagle Rods
JE high dome pistons 11.5:1 cr
Z10 girdle
New bearings throughout
this will be in a EG hatch for pretty much street/strip use....
Old Aug 22, 2001 | 10:08 PM
xJ.SLOTHx's Avatar
Default Re: some B20 questions... (ian)
oh and i forgot to add that i will be using a Type R oil pump and the crank will be knife edged....thanks
Old Aug 23, 2001 | 12:12 AM
976's Avatar
976
New User
I couldn't guestamate the hp. But it will be quick... Thats for damn sure!
Old Aug 23, 2001 | 03:56 AM
stretracr's Avatar
Default Re: some B20 questions... (prsi)
I'd clay that first. Those clearances will be real tight. It might not work with those cams and pistons.
Old Aug 23, 2001 | 10:58 AM
bigTom's Avatar
i think if it doesn clear it would be barely... someone i know with a gsr... had 12.5:1 comp and i forgot what cams... some high lift ones and he was tapping the pistons
Old Aug 23, 2001 | 12:02 PM
xJ.SLOTHx's Avatar
ookok, what if i used some CTR / ITR mismatch cams....with the initial setup, over the Jun products. thanks
K_pem
Jul 2, 2011 07:45 AM
hpimichael02
Nov 5, 2008 11:37 AM
B20 Civic
Jan 29, 2008 05:58 AM
B20 Civic
Jan 18, 2008 06:09 AM
snowseeker
Aug 31, 2004 11:33 PM
