B18a1 swap into 89 crx si
Old Sep 19, 2003 | 07:18 PM
dan89crxsi's Avatar
Default B18a1 swap into 89 crx si
Hey I blew up my D16a6 and I have a B18a1 ready to go into my crx I need some help and some pics of one being done anyone know where i can find some information on doing this and some pics of it being done this will be my first swap and I need some info
Old Sep 19, 2003 | 08:24 PM
civickiller's Avatar
Default Re: B18a1 swap into 89 crx si (dan89crxsi)
u dont need pics, you need to know what needs to be done to get it runnin good.
you need engine tranny ecu axles
90-93 throttle cable for special bracket to run si throttle cable
u can use your stock clutch cable, but a 90-93 fit perfect and makes it look good
you need mounts so the new motor will fit
upper and lower 90-93 teg ls radiator hoses
dont forget to make a dent in the frame below drivers side shock tower
Old Sep 21, 2003 | 11:29 AM
JDMHatch101's Avatar
first off the frame on the drivers side where the altenater is needs to hammered in, in about a three inch circle. second if you dont have the mounts you need to get them they will have the instructions with them. second if your car is a dx or std you need to get all of your wiring done NOW before you put the motor in. when you put the motor in make sure you have one or two people there to help you. that should be about it hit me back if any questions.
Old Sep 21, 2003 | 07:34 PM
dan89crxsi's Avatar
Default Re: (DX2B16A(SIR))
I have a Si and all I am worried about is the wiring and all the hoses I am pretty confident on actually just bolting the b series in there
CRXDragon
Classic Hondas
Nov 26, 2010 09:47 PM
-HONDA-
25
Mar 25, 2007 01:09 PM
ImportsCRX
Oct 26, 2005 02:01 PM
yellowCRX6
Jan 24, 2004 08:49 PM
djay86
Mar 30, 2002 12:48 AM
