cost of converting automatic civic transmission to manual transmission
Old Sep 19, 2003 | 06:40 PM
blizzack901's Avatar
Default cost of converting automatic civic transmission to manual transmission
If I were to change the auto tranny to a manual, about how much do you think it would cost overall if I did it myself. I want to get a hydraulic tranny, like a gsr one. Thanks.
Old Sep 19, 2003 | 06:52 PM
Smith Wise's Avatar
Default Re: cost of converting automatic civic transmission to manual transmission (blizzack901)
car?? engine?? I assume LS Integra.
More info please
Old Sep 19, 2003 | 08:02 PM
Default Re: cost of converting automatic civic transmission to manual transmission (Jswpstdoff)
sorry, the conversion would be on either a '94 civic dx hatchback or a '96 integra ls.
Old Sep 19, 2003 | 08:13 PM
blackhatchy's Avatar
try searching for it, this has been covered and should be easy to fimd
Old Sep 19, 2003 | 08:16 PM
Smith Wise's Avatar
Default Re: cost of converting automatic civic transmission to manual transmission (blackhatchy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhatchy &raquo;</TD></TR><TR><TD CLASS="quote">try searching for it, this has been covered and should be easy to fimd </TD></TR></TABLE>
this is one I did this summer, any questions? won't cost much if you do it yourself.
My auto to 5spd convo
Old Sep 19, 2003 | 08:19 PM
im probably getting a b16a2 or b18c
Old Sep 20, 2003 | 03:41 PM
So after the conversion was all done did u get any heat or air getting through? Did you have to use a heat shield. Good job on the swap.
Old Sep 20, 2003 | 03:43 PM
if done correctly, you shouldnt get any more than it would stock.
Old Sep 20, 2003 | 08:40 PM
HuskerHybrid's Avatar
done 3 already... it's not too bad.
Old Sep 20, 2003 | 09:05 PM
GPwhiteDB8's Avatar
you can expect to pay like 300-400 for the parts....i looked into it on an EG
Old Sep 20, 2003 | 09:08 PM
bartek_b's Avatar
Labor will be around 1200.00.
a sex change isn't a cheap procedure
Old Sep 23, 2003 | 09:51 AM
GPwhiteDB8's Avatar
which is why you diy. you have got to on projects like these....oh and hte 300-400 is just the interior swap, when i was looking into it, it was with a swap so i would be getting hte tranny anyway. its not cheap but if you are determined, and i respect u for it, then its worth it
intentive
Jun 9, 2006 10:00 AM
Gods own
May 24, 2006 06:47 PM
errrrbaaaa
Apr 11, 2006 05:05 PM
CD8coupeSiR
Jan 6, 2006 08:58 PM
