Does short ram install require resetting the ECU?
Old Sep 19, 2003 | 05:51 PM
another_preluder's Avatar
Default Does short ram install require resetting the ECU?
Old Sep 19, 2003 | 06:15 PM
NirVTEC's Avatar
Default Re: Does short ram install require resetting the ECU? (another_preluder)
It wouldn't be a bad idea.
*****MAKE SURE YOU HAVE YOUR RADIO CODE*****
Old Sep 19, 2003 | 06:25 PM
MileHigh's Avatar
dont think it's required... I'd do it
*****dont forget to set your clock if you do unplug*****
Old Sep 19, 2003 | 06:27 PM
madcatz's Avatar
Clint why are you blowing smoke up his bum?
Just messing, you dont "Have" to, but its just something to re-set the ECU, I did it after every mod, I/H/E, and about once a month
Old Sep 19, 2003 | 09:02 PM
sharkcohen's Avatar
Resetting the ecu once a month is not at all effective. The ecu "relearns" (modifies the long term fuel trim) within the first hours of driving. The OBDII "workaround" (snipping the ecu memory wire and optionally putting an SPST switch on the wire) is a much better option, as the ecu will be reset every single time you shut down the car.
Old Sep 20, 2003 | 07:01 AM
NirVTEC's Avatar
Default Re: (madcatz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz &raquo;</TD></TR><TR><TD CLASS="quote">Clint why are you blowing smoke up his bum?</TD></TR></TABLE>
I learned the hard way about the Radio code. I bought my car used, didn't have the owners manual, and because of a combination of stupidity and laziness drove around for weeks w/o tunes!
Just trying to save a fellow Luder some hassle.
To add to that, anyone that wants DO's and DON'T's of Power Steering removal: I can help you there too. No trust me, its not necessary to flood your friends driveway with p/s fluid!
rizzuto
14
May 17, 2013 07:59 PM
vinuneuro
Jul 25, 2008 11:58 PM
O RLY
10
Jul 2, 2007 07:28 AM
Spy1r
Mar 3, 2004 08:30 PM
tiresmoke
Feb 26, 2004 10:24 PM
