perfect offset for azeenes 205 50 15
Old Sep 19, 2003 | 04:06 PM
dj_seloe's Avatar
Default perfect offset for azenis 205 50 15?
I want to know what the perfect offset would be for the tires anybody know???
Modified by jdmef9RHD at 11:12 PM 9/22/2003
Modified by jdmef9RHD at 7:48 PM 9/23/2003
Old Sep 19, 2003 | 04:14 PM
Project91CRX's Avatar
Default Re: perfect offset for azeenes 205 50 15 (jdmef9RHD)
what have you always been running with?
Old Sep 19, 2003 | 04:57 PM
XrcR6's Avatar
Depends, first what wheel width are you going to go with? The same offset, on different width wheels, with the same tire will give the different results (different track, clearances change, etc.).
I guess the two obvious choices are going to be a 15x6.5" ( probably +40 to +45) or 15x7" (+35 to +40). So you should figure out which of those and what brand and then what's available.
Do you need to clear big brakes? That may change dictate a lower numerical value to push the wheel out.
I'm thinking 15x7", since the Falken Azenis is known to be wider-than-indicated tire.
Old Sep 19, 2003 | 06:10 PM
Todd00's Avatar
I said I don't want a title!
Roughly +42, +43 in a 15x7 wheel. Other width wheels will vary, but I know those will fit.
Old Sep 22, 2003 | 09:54 AM
dj_seloe's Avatar
Default Re: perfect offset for azeenes 205 50 15 (Todd00)
I got 15'' by 7 rotas I think the offset is 35 and im chewing up my tires!!!!!
Old Sep 22, 2003 | 02:12 PM
dj_seloe's Avatar
Old Sep 22, 2003 | 03:23 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmef9RHD &raquo;</TD></TR><TR><TD CLASS="quote">I got 15'' by 7 rotas I think the offset is 35 and im chewing up my tires!!!!!</TD></TR></TABLE>
Why? Are you rubbing the fenders?
I am thinking to get some 15 X 7" and run 205's, but I want a +40 offset. Do you think that will clear everything?
Old Sep 22, 2003 | 03:34 PM
dj_seloe's Avatar
Default Re: perfect offset for azeenes 205 50 15 (4drEF)
yeah im rubbing the fenders...
but i think the offset your going with is coo you won't have any prob's.
Old Sep 22, 2003 | 06:17 PM
slywfbpsi's Avatar
I thought the rotas only came in 15x6.5?
Old Sep 22, 2003 | 11:25 PM
SiZ's Avatar
SiZ
Anything less than +40mm will most likley rub.. Well, from my experience.
I had a set of 15s with a +35mm offset and 195/55/15s and they rubbed like a ****.
A set of 16s with a +38mm offset and they rubbed, but only on corners and when the car was reall lowered down.. Not as much as the 15s.
Then another set of 16"s with a +40mm offset, and they would tuck just fine.. Never rub.
Old Sep 23, 2003 | 10:35 AM
4drEF's Avatar
Keyboard Humorist
Default Re: (SiZ)
Ok, just found out that the 15" wheel I want is only offered in a 35 offset. It's a 7" wide wheel... I can get a 6.5 though. I was set on getting the 7" with a 40, but.... no 40! DAMN!
So, if I get the 7" wide wheel will runnign a 195/50 tire rub? If so, how much?
Old Sep 23, 2003 | 10:42 AM
markedOO1's Avatar
Default Re: (4drEF)
45 is the only way to go
Old Sep 23, 2003 | 10:53 AM
dj_seloe's Avatar
Default Re: (markedOO1)
Your right 6.5 for the rotas
don't get the 35 offset your gonna rub!!!!
I have to get rid of mine can anybody help a brotha out?????
Old Sep 23, 2003 | 11:12 AM
slywfbpsi's Avatar
Default Re: (jdmef9RHD)
the rotas are in a 38+ offset I think the main reason you may be rubbing is the 205/50 azenis, they are actually wider than a regular 205/50 tire.
Old Sep 23, 2003 | 11:56 AM
CRX-RX's Avatar
Default Re: (slywfbpsi)
Actually all of the info on the 15X7 rota slipstreams that I have seen is a 40mm offset. The 6.5's are also a 40mm offset. The circuit 8's have a 38mm offset, and I have seen those rub a little on a CRX, but the Civic hatch has more rear wheel clearance on the fenders than the CRX. So do you have these rims, or are you thinking about getting them?
Old Sep 23, 2003 | 12:55 PM
dj_seloe's Avatar
Default Re: (CRX-RX)
I have seen them on a hatch with the same rotas, and no rub!!!!
yes I have them, they rub to much but I don't have anything else to put on, that's why I need to get rid of them,the rim are mint tires? the two front the inner are worn the rear has about 75%still on them just I lil slashed from the fenders.
If you want to check them out go to vehicle for sale and look for california reg. RHD for sale or trade my boy put it up for me.
Old Sep 24, 2003 | 06:58 AM
dj_seloe's Avatar
^^^^^^ for the morning&gt;&gt;&gt;
jdmgirl90
Feb 2, 2014 08:50 PM
STN_Pat
Oct 17, 2011 06:59 AM
mattcx
Jul 14, 2009 08:35 PM
mrchris1979
Feb 3, 2008 12:15 PM
Mike D
Jul 31, 2002 09:52 AM
