engine light on after itb's install
Just finished installing my TWM itb's on a B18c1,now code 10 and 14 appear iat and iac.Cant seem get of rid codes,please help,plus car bogs at low speed has erratic idle but runs ok at wide open throttle.
reset the ecm then idle the car for like 15 min. sounds like the idle air controll valve. thats why you have a weird idle! and make sure all the sensors are hooked up. hope that helps
ok I tried that but the car still ides up and down and feels like its missing under load.I played around with the butterflies and linkage I just want the car to idle so I can take it to get tuned.
The car is bogging at lower rpm's because with the ITB's, there is less vacuum and its fooling the ecu into dumping more fuel down low. Most likely gonna need to reburn the chip or use a vafc to correct for the extra fuel down low.
You can out the IAT sensor right in front of one of the horns.
As far as the IACV, there are a couple ways of keeping it happy. CHEETAH recommended bolting it to a plate, and keeping coolant running through it. "Mount your IACV into a plate to block off and pass coolant thru it but not connected to anything except stock engine harness (pass coolant thru it or the car will keep revving up and down from 1K to 4k then back to 1K etc)"
Also what injectors are you running? are you using the vacuum or non vacuum dependent FPR? Using a vacuum canister?
I'am using a chipped p28 with a burned program and vafc.I have a vacuum cannister from TWM and suitable sized injectors.I had the car idleing fine even with not running coolant through the iacv.The problems all started after I messed around with the butterflies.
RockinthEFhatch
71
Jan 18, 2025 01:45 PM
oranginal
Jul 26, 2006 07:54 AM
VTcivicHB
21
Oct 31, 2005 08:01 PM
