Is it hard to install jdm headlights in a 90 teg?
Old Sep 19, 2003 | 11:09 AM
90da's Avatar
Default Is it hard to install jdm headlights in a 90 teg?
I just want to know what is involved with installing jdm headlights in a da9. Any write ups or info would be great.
Old Sep 19, 2003 | 11:13 AM
thaiphob's Avatar
Nikon!!!
Default Re: Is it hard to install jdm headlights in a 90 teg? (90da)
its pretty much strait forward just unscrew and rescrew thats all.
Old Sep 19, 2003 | 12:01 PM
90da's Avatar
Default Re: Is it hard to install jdm headlights in a 90 teg? (thaiphob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">its pretty much strait forward just unscrew and rescrew thats all.</TD></TR></TABLE>
Thats pretty much what I figured....just wanted to make sure. Thanks
Old Sep 19, 2003 | 12:18 PM
thaiphob's Avatar
Nikon!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90da &raquo;</TD></TR><TR><TD CLASS="quote">
Thats pretty much what I figured....just wanted to make sure. Thanks</TD></TR></TABLE>
np one more thing the 1pc uses H4H bulbs so you might get those b4 you put on the lights
Old Sep 19, 2003 | 12:34 PM
mr.beeks's Avatar
well you need an extra hand
first remove the screws that are on the fender well two on each side philips
second remove signal lights and you will find two bolts holding up the bumper
support take them off
and the whole bumper will drop off
now look for the bolts that hold the light and thats it
but the tricky part is the following
to hook up the lights the current plugs dont work so you are going to have to cut
and change the plug harness in order to plug into the headlight bulbs
use your runing/blink light for the corner cause you wont use the running light
for this installation then put back together.
ps hopefully you have your bulbs in there cause they are JDM and no american bulb fits there unless you modefy..
Old Sep 19, 2003 | 01:14 PM
90da's Avatar
Default Re: Is it hard to install jdm headlights in a 90 teg? (big reds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big reds &raquo;</TD></TR><TR><TD CLASS="quote">well you need an extra hand
How can you modify the light? The only thing I have seen is the wiring. I would like touse the normal H4 bulbs, as I don't feel like spending $100 for bulbs.
Old Sep 19, 2003 | 01:18 PM
mr.beeks's Avatar
go to teg tips on
http://www.g2ic.com
they will cover the conversion to H4.
Old Sep 19, 2003 | 05:10 PM
90da's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big reds &raquo;</TD></TR><TR><TD CLASS="quote">go to teg tips on
http://www.g2ic.com
Thanks again...that site is pretty good for the JDM light conversion.
lilazn71
Oct 16, 2007 02:30 PM
sickassride
Jul 4, 2006 10:42 PM
law_teg_92_R
Jun 9, 2005 10:19 AM
53JDMDC2
Sep 9, 2004 09:27 AM
etnavyman
Apr 24, 2004 02:56 PM
