Will integra struts and springs fit on a 97 civic with a 98 integra brake conversion?
Old Sep 19, 2003 | 09:45 AM
Fallen's Avatar
Default Will integra struts and springs fit on a 97 civic with a 98 integra brake conversion?
Just as the topic says. I have a 97 civic with a 98 integra brake disc conversion on it. I wanted to know if integra struts will fit.
thanks
Old Sep 19, 2003 | 09:54 AM
EL Vap133's Avatar
Default Re: Will integra struts and springs fit on a 97 civic with a 98 integra brake conversion? (Fallen97)
Good question, the fronts should, but for the rear what LCAs are you using?
Old Sep 19, 2003 | 10:03 AM
slammed_93_hatch's Avatar
Default Re: Will integra struts and springs fit on a 97 civic with a 98 integra brake conversion? (EVIL_Vap1
yes they will fit unless you have typeR suspenion
Old Sep 19, 2003 | 10:32 AM
CXHatchback's Avatar
He HAS to be using his own lcas, teg ones don't fit.
In short yes they will work but you'll need to add washers to the rear lcas since the fork is wider in the rear.
boostitalready
Nov 25, 2012 04:36 PM
LoGaN-VanG
Jun 8, 2012 12:04 PM
mik101
Feb 2, 2006 07:31 AM
