Odd sound on the front left side...
Old Sep 19, 2003 | 09:15 AM
handa's Avatar
Default Odd sound on the front left side...
There's an odd sound on my car. It is located around the front left side of my car. When I drive it...it behaves normally. But when I step on the brake at certain point, it starts to rattles. I'm not sure if it is a brake, caliper, or an axle issue.
Recent installations include new CV joint on that side, new premium brakes a month ago, and lowered my car with DZ coilovers.
Old Sep 19, 2003 | 10:14 AM
slammed_93_hatch's Avatar
Default Re: Odd sound on the front left side... (handa)
most likely there t metal peaces close together and at the right point they rattle just get uder there and make sure every thing is tight
Old Sep 21, 2003 | 12:43 AM
EK9Greg's Avatar
it sounds like you need to brake pads. They mite not be worn down te pad can crack under climit changes. Not something people think about check them out. The crack can be inside the pad too. Puch down on both sides of the pads and see if you can find a soft spot. Good luck
msinsky14
May 24, 2007 06:00 PM
Naturally Aspirated
Sep 3, 2004 11:12 PM
jond
Jun 27, 2003 01:03 PM
216.226.142.95:27016
Apr 9, 2003 07:55 PM
KingJeff
Sep 9, 2002 10:48 AM
