trouble starting, clutch sensor?
Old Sep 19, 2003 | 08:17 AM
p0pe's Avatar
Default trouble starting, clutch sensor?
When I turn the key, I just hear a click but it doesn't turn over and start until I pump the clutch once or twice, then it starts right away. Could it be the clutch sensor gone bad or damaged some how? What are some other possible causes?
Old Sep 19, 2003 | 09:53 AM
JimBlake's Avatar
Default Re: trouble starting, clutch sensor? (p0pe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0pe &raquo;</TD></TR><TR><TD CLASS="quote">... Could it be the clutch sensor gone bad or damaged some how?</TD></TR></TABLE>That's my guess. Find the clutch switch (buried up above the pedal, maybe not real easy to find). If there's nothing obvious like a loose or bent bracket, then jumper the wires together. That'll tell you whether the switch is the problem.
91H4hatch
Jan 16, 2008 01:16 PM
99cpevtec
Jul 15, 2005 02:27 PM
yaleforizzle
Dec 8, 2003 06:34 AM
p0pe
Sep 20, 2003 07:52 PM
