Seal S6 Question or PVS question..
lol...
I know that Teins, etc. must be turned a certain way. I'm not sure about the Zeals though.
Hopefully your alright and you haven't ruined your JDM blings by only turning clockwise
True, maybe I'm making this more difficult that it has to be seeing as how the PVS is clearly labeled
Turn up the range to go stiffer 3-4-5, turn down the range for less 5-4-3
I'm an idiot sometimes. I guess working on a Friday will do that to you.
A lot of that later to make me feel better
i think i turn in whatever direction is closest to the number i am looking for....
if i had to pick a direction, clockwise. but, i haven't changed my dampening setting for some time (4 front 5 rear)
the zeals spin completey free, the teins stop.
you can most likely turn the zeals in any direction.... infinate times. since they have numbers you always know what setting it is on.
to adjust the teins set them to max tight, then back off the desired # of clicks up to 16... however, it will click 24 times. the last 8 clicks do not adjust it past the 16th, the softest setting, and will damage the shocks.
killafred187
May 16, 2007 09:08 PM
