Problem with Passenger side Window
Old Sep 19, 2003 | 03:11 AM
Full-Race Henry's Avatar
Default Problem with Passenger side Window
Hey everyone, I have a problem with my passenger side window. Its a 2000 si with power windows. When i try to roll it up or down from the drivers side, it goes up or down a little then stops. but when i do it from the passenger side, it works fine. anyone have this problem or know how to fix this?
Old Sep 19, 2003 | 03:17 AM
PornstaR16L's Avatar
sounds like a bad switch or wiring. take it apart and check with a voltmeter. If you have a warrenty take that damn thing back!!
Old Sep 19, 2003 | 09:51 AM
Default Re: (PornstaR16L)
ttt
Old Sep 19, 2003 | 11:35 AM
Default Re: (EF8_Fan)
i dont think the warrenty covers this. does anyone know?
Old Sep 19, 2003 | 11:41 AM
vtecmonster's Avatar
Sounds like something is touching. I would just check it out yourself.
Old Sep 19, 2003 | 02:08 PM
EKtypeRhaTcH's Avatar
my friends ex had the same problem, it just fell off the track..just remove the side panel and then you have to take out the window and push it in again from the top so it will be on the tracks again...hope that helps
Old Sep 19, 2003 | 04:11 PM
KiddEng's Avatar
Default Re: (EKtypeRhaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKtypeRhaTcH &raquo;</TD></TR><TR><TD CLASS="quote">my friends ex had the same problem, it just fell off the track..just remove the side panel and then you have to take out the window and push it in again from the top so it will be on the tracks again...hope that helps</TD></TR></TABLE>
i dont think this is the problem he is having...although this is a common problem of the window falling off the track. me being one of them.
hes saying that its the pass window, using the driverside switches doesn't go all the way up or starts to go but then studders and stops.
-i would go and test the drivers side switch/control modual. a few days ago my driver switch was acting funny too and would not roll up or down the window... i busted out the service manual and started running down the tests for each of the circuits w/a volt meter. and found that i did have a bad driver side modual
if the window works from the passenger switch, i'd test the drivers side...most likely ur switch is dead. or bad connection...
good luck
Modified by KiddEng at 3:36 PM 9/20/2003
Old Sep 20, 2003 | 11:09 AM
Default Re: (KiddEng)
thx kiddeng has anyone had this happen to them before?
Old Sep 21, 2003 | 12:38 AM
ttt
Old Sep 21, 2003 | 10:37 AM
up
Old Sep 22, 2003 | 12:13 PM
KiddEng's Avatar
man still havn't tested the switch yet huh?! just do it now, and if it fixes it...no need to bump. if it doesn't then atleast u tried something to fix it.
TEST THE SWITCH!
Shushiplease
Jun 25, 2008 05:12 AM
2wir3d
Honda Civic (2001 - 2005)
Jul 21, 2007 05:20 AM
Slammed_am
Nov 14, 2005 11:29 AM
