ITR 1-4 gears into a gsr tranny ? ?
Old Sep 18, 2003 | 10:15 PM
rodimus's Avatar
Default ITR 1-4 gears into a gsr tranny ? ?
i went to the dealer and there were not only just "gears" in the tranny...
there was a whole mess of ****.
what exactly will i need to do this swap..
anyone got part numbers?
Old Sep 19, 2003 | 08:14 AM
pro1342's Avatar
The price of buying the 1-4 gear sets, on the main and counter shafts, you can almost buy a whole ITR trans.
Old Sep 19, 2003 | 08:49 AM
NeoGSR's Avatar
Default Re: (pro1342)
get a ITR tranny and swap out the 5th gear in that.....i assume you want the 5th gear to be lower for highway.....me too!!!
Old Sep 19, 2003 | 08:58 AM
Slappy's Avatar
Default Re: ITR 1-4 gears into a gsr tranny ? ? (EVOL)
What are your plans for the motor?
1-2 gear set is going to run $450 new from dealer
3-4 gear set is about $300 new from dealer
These are prices for the syncros and the gear.
The countershaft will be right at $295.00
You also might have to replace a couple of the shift forks, as they possibly might not line up.
Good luck.
Old Sep 19, 2003 | 07:07 PM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 &raquo;</TD></TR><TR><TD CLASS="quote">The price of buying the 1-4 gear sets, on the main and counter shafts, you can almost buy a whole ITR trans.</TD></TR></TABLE>
itr tranny retail from dealer 2700.
used trannies u always take a risk.
this way i can spend just as much, and know what's in the tranny.
that to me is not a bad deal at all.
Old Sep 22, 2003 | 01:31 PM
rodimus's Avatar
Default Re: (EVOL)
MT MAINSHAFT
16339 010 1 SLEEVE SET (5-R) 134.88
16289 008 1 GEAR 73.21
16247 007 1 WASHER (20X30X4) 4.90
16214 006 1 GEAR, REVERSE IDLE 45.00
16042 005 1 GEAR 86.58
15992 004 1 GEAR SET 245.33
15945 003 1 GEAR 139.74
15780 002 1 SHAFT 22.00
15666 001 1 MAINSHAFT 255.96
MT COUNTERSHAFT
16187 007 1 SLEEVE SET (1-2) 308.63
16145 006 1 GEAR 58.74
16100 005 1 GEAR 53.87
16067 004 1 GEAR 45.96
15901 003 1 GEAR 83.15
15815 002 1 GEAR 75.89
15721 001 1 COUNTERSHAFT 261.06
i'm only interested in swapping gears 2nd and 3rd.
fd and lsd i have a source for. anyone know exactly what to point out between these two pics?
Modified by EVOL at 2:45 PM 9/22/2003
SoOHiGH
Oct 20, 2006 08:27 PM
tinkerbell
Aug 10, 2006 07:24 AM
rodimus
23
Sep 26, 2003 09:01 AM
IC x Prince
Jan 27, 2003 09:39 AM
JDMEMM
Oct 24, 2002 10:57 AM
