shifting problem
Old Sep 18, 2003 | 10:08 PM
93SIRII's Avatar
Default shifting problem
I have a serious problem over the last few days my tranny has made it dam near impossible to shift, all gears have become tight espacially third, its almost impossible to shift espacilly driving hard Its even grinded it I really have to force it into gear. I've tried flushing the tranny but no luck its getting worse by the day are my syncros going in every gear and whats the matter with third??
Old Sep 18, 2003 | 10:15 PM
Sketch_hs's Avatar
Default Re: shifting problem (93SIRII)
how many miles?
when the car is off and you push down the clutch pedal is it easy to shift it?
could be a shift linkage problem.
Good luck.
-Sketch
Old Sep 18, 2003 | 10:27 PM
intezn's Avatar
Default Re: shifting problem (Sketch_hs)
if i put 10w30 into the tranny.......
am i suppose to change it every 3000 miles?
Old Sep 18, 2003 | 10:53 PM
Sketch_hs's Avatar
Default Re: shifting problem (intezn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intezn &raquo;</TD></TR><TR><TD CLASS="quote">if i put 10w30 into the tranny.......
am i suppose to change it every 3000 miles?</TD></TR></TABLE>
i'd use HMT and it's like every 10-15k i think?
Old Sep 18, 2003 | 11:03 PM
93SIRII's Avatar
Its easy to shift when the enigine is running and the clutch is on the floor
Old Sep 18, 2003 | 11:06 PM
93SIRII's Avatar
sorry when the car is off its easy to shift it feels like it used to before it started to brake.
Old Sep 19, 2003 | 04:24 AM
goodbyegti's Avatar
it could be your clutch, get it looked at before your tranny dies a nasty death...
Old Sep 19, 2003 | 05:38 AM
Navid OG's Avatar
well non of us can tell u exactly what it is. My friend had somewhat of the same problem but his was worse, he had a hard time putting it in every gear, and it stopped going into R. When we took it to the shop the guy said there is no way he can know until he opens it, when he did we found out that his syncros were not in the best shape, his forks were fucked, and that he had some shift linkage problems, and more stuff i cant remember at the moment. The funny thing was the Mechanic knew this happened because of racing, he said "so did u at least win ur races" so i guess this is a common problem with people that drive hard. anyways good luck
Old Sep 19, 2003 | 07:25 AM
jerseybrandon's Avatar
it does sound like linkage or shift fork. check the hydralic components too.
Old Sep 19, 2003 | 07:28 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">
i'd use HMT and it's like every 10-15k i think?</TD></TR></TABLE>
actually Honda recomends every 30k.
I change mine twice a summer, and store it winters.
Old Sep 19, 2003 | 08:24 AM
2camsaam's Avatar
Check: Clutch Master cylinder
Old Sep 19, 2003 | 08:36 AM
pro1342's Avatar
Check the clutch master and slave cylinders first, but it sounds like your clutch disc took a dump. One of the springs popped out or the material is coming off the disc.
Old Sep 25, 2003 | 01:46 PM
92 civic VX B18c's Avatar
HT Black Ops
So did you figure out what the problem is? I'm interested to know
Old Oct 6, 2003 | 10:12 PM
HT Black Ops
Default Re: shifting problem (92 civic VX B18c)
I was having the same problem and this was what was causing it I think the stray piece of metal was one of the clutch disk's counter weights it came out from behind one of the four springs on the disk and got stuck between my disk and my pressure plate...
I was so glad to find out it wasn't my tranny
bryanxwhite
Sep 24, 2008 05:02 AM
JDubbs99Civic
May 8, 2005 09:44 AM
Skinnypunk
May 30, 2004 10:41 AM
skunk2unerz
Sep 4, 2003 06:05 PM
boomslang
Nov 18, 2001 12:00 AM
