do you do a burnout w/bf drag radiels
Old Sep 18, 2003 | 09:51 PM
fastludeh22's Avatar
Default do you do a burnout w/bf drag radiels
i know its pointless w/normal street tires, but the drag radiel is supposed to be different. im getting them mounted tomarow, then going to the track. do they grip better after a burnout?
Old Sep 18, 2003 | 10:24 PM
ISELLRIGHTHANDDRIV
Guest
Posts: n/a
Default Re: do you do a burnout w/bf drag radiels (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">i know its pointless w/normal street tires, but the drag radiel is supposed to be different. im getting them mounted tomarow, then going to the track. do they grip better after a burnout?</TD></TR></TABLE>
yes!
Old Sep 18, 2003 | 10:37 PM
allmtr's Avatar
Default Re: do you do a burnout w/bf drag radiels (ISELLRIGHTHANDDRIVES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISELLRIGHTHANDDRIVES &raquo;</TD></TR><TR><TD CLASS="quote">
<u>yes!</u> </TD></TR></TABLE>
Old Sep 19, 2003 | 10:01 AM
1320ForLife's Avatar
ENOUGH SAID.
Old Sep 19, 2003 | 01:06 PM
civickiller's Avatar
Default Re: do you do a burnout w/bf drag radiels (1320ForLife)
yeah but just because they grip better, doesnt mean youll run a faster time, too hot and youll have a good 60foot but a slow 1/4 time
Old Sep 19, 2003 | 05:56 PM
TREVER's Avatar
Default Re: do you do a burnout w/bf drag radiels (civickiller)
It helps clean the debris off too.
Old Sep 19, 2003 | 06:16 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">yeah but just because they grip better, doesnt mean youll run a faster time, too hot and youll have a good 60foot but a slow 1/4 time</TD></TR></TABLE>
How is that?
Old Sep 19, 2003 | 07:35 PM
allmtr's Avatar
elaborate...
Old Sep 21, 2003 | 08:27 AM
makes no sense too me....i think he is trying to say they'll be soo sticky it would slow you down...
Old Sep 21, 2003 | 09:14 AM
slowsi00's Avatar
do a DRY burnout
it will help out
at the very least it will clean off the rocks
Old Sep 21, 2003 | 06:42 PM
80884's Avatar
Default Re: do you do a burnout w/bf drag radiels (slowsi00)
mine hooked much better after a nice smokey burnout, but i had to at least get the tires wet in order for them to spin without taking my car for a ride.
Old Sep 21, 2003 | 08:09 PM
JonW757's Avatar
burnout will help!
Old Sep 21, 2003 | 09:03 PM
dmotoguy's Avatar
Default Re: (JonW757)
you might not have as high as a trap speed if you hook up good out of the hole, but your et will almost always be better
burn em
Old Sep 21, 2003 | 09:06 PM
sporkcrx's Avatar
Default Re: (dmotoguy)
Now that's a question I'm curious about...burn em wet, or dry?
Old Sep 21, 2003 | 09:19 PM
dmotoguy's Avatar
Default Re: (sporkcrx)
most people i have seen drive through the water and then burn them, they need a little moisture to get them going but dont want too much
Old Sep 22, 2003 | 11:13 AM
Stunna BEN's Avatar
Don't call it a comeback
I have gotten really good traction from just Cleaning the tires off a lil. Not doing a huge burnout, and just turning them over a few times. Saves time, motor, and Pocket
Old Sep 22, 2003 | 07:04 PM
80884's Avatar
yea just get tires wet via drive through, not spinning in the wet, that would not be good unless you are planning on doing a burnout long enough to dry the water that you just threw all through your inner fender area. Plus they don't alow burnout while sitting in the water at my track. brings too much water up to the starting line from dripping off your car.
ok i'll shut up now
Old Sep 23, 2003 | 12:09 PM
Default Re: (80884)
yeah too hot and they are too sticky and slow you down. seen done on street tires as well as slicks. street tires from personel experience, slicks from looking at friends time slips. did a short dry burnout, got a alittle slower 60 but overall faster 1/4, long burnout good 60 but slower 1/4
Old Sep 23, 2003 | 12:11 PM
allmtr's Avatar
Default Re: (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">yeah too hot and they are too sticky and slow you down. seen done on street tires as well as slicks. street tires from personel experience, slicks from looking at friends time slips. did a short dry burnout, got a alittle slower 60 but overall faster 1/4, long burnout good 60 but slower 1/4</TD></TR></TABLE>
r u talking bout mph or et?
Old Sep 23, 2003 | 12:33 PM
Default Re: (allmtr)
both where alittle slower
Old Sep 23, 2003 | 03:47 PM
Stunna BEN's Avatar
Spin the tires off the line and youll see the higher MPH
Old Sep 23, 2003 | 11:08 PM
Gerhard_001's Avatar
You need to substantiate this claim, I run the BFG radials and this makes no damn sense, it simply defies the laws of physics. You need to get these tires wet they 'will not' dry burnout unless you are pushing sick amounts of power. These tires need to be hot to get the benefit they provide over street tires. Slower quarter mile time has more to do with the tire pressure in these tires. These tires are sensitive to the weather conditions, if it is hot outside or the sun is beating down you will gain tire pressure, cold outside or no sun beating down on the tires you will lose pressure. In other words you are either losing pressure or gaining pressure with these tires and you need to check the pressure frequently right befor every run, that would be the cause for any inconsistencies in your quarter mile times, not the heat of the tires.
Old Sep 24, 2003 | 12:03 AM
oMek's Avatar
Default Re: do you do a burnout w/bf drag radiels (Gerhard_001)
just a quick question. do you guys run these tires 24/7? or are they your track only tires. im just askin because im thinking of getting some and ide figure they would wear out quicker if used as reg driving tires?
Old Sep 24, 2003 | 12:27 AM
96dc2's Avatar
Default Re: do you do a burnout w/bf drag radiels (omekone)
It'd be a waste to drive on the BFG's everyday. The Nitto's will be better for that.
Old Sep 24, 2003 | 02:09 AM
TEAMGENDAI's Avatar
Default Re: do you do a burnout w/bf drag radiels (96dc2)
YES. Get them about 110 degrees!!
