grounding wires
Old Sep 18, 2003 | 08:08 PM
jordan88's Avatar
Default grounding wires
hi, i have a 98 civic ex coupe d16y8 standard, i am thinking to put on some grounding wires. i am preparing to do it myself, has anyone did it theirselves before by just buying wires from auto store and put them on. can i have some installation instructions?
what guage of wires should i get?
where are the mounting points?
what are the parts i needed?
thx
Old Sep 18, 2003 | 08:19 PM
infinatenexus's Avatar
Default Re: grounding wires (jordan88)
I used 8G wire, and crimp on rings
I ran them from:
Alternator-frame
Throttlebody- firewall
Dizzy-radiator support
Block-frame
Old Sep 18, 2003 | 09:30 PM
it starts a little quicker
the throttle response was better
radio sounds cleaner
Old Sep 18, 2003 | 09:36 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (infinatenexus)
I made my own as well. Throttle response was better and idle smoothness increased .
Old Sep 18, 2003 | 09:37 PM
HXvtec's Avatar
i heard these wires take some time to find the best ground.
Old Sep 18, 2003 | 09:40 PM
Umm what??
Old Sep 18, 2003 | 09:43 PM
Unceasing Measure
I grounded all mine back to the battery...that's about as good a ground as it gets .
Old Sep 18, 2003 | 09:49 PM
I would go take some for ya,, but the motor is kinda missing,, so it wouldn't show much.
I just used a mounting bolt for the TB to mount the ground wire on mine
Old Sep 18, 2003 | 10:22 PM
happies713's Avatar
http://www.imagestation.com/pi...e.jpg
i make my own and sell them online. shooot me a pm. if you are interested.
Old Sep 19, 2003 | 06:17 AM
99lsvtecauto's Avatar
Default Re: (happies713)
i want a red one they look nice what's that 4 gauge is the same wires a want comes in an amp wiring kit . do u have different lengths
Old Sep 20, 2003 | 05:52 AM
Yokohama's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">I grounded all mine back to the battery...that's about as good a ground as it gets .</TD></TR></TABLE>
WHY?!?!?!?!?
the battery isnt a ground point...it gets grounded as well...try grounding to the proper spots with good size wire and see if you notice a difference
Old Sep 20, 2003 | 11:24 AM
Slammedciv96's Avatar
actually the battery is a good grounding point... energy moves in a cycle.. the battery isnt grounding to the frame the.. the frame is grounding to the battery... i can teach you basic electronics if you need... but in reference its not good to run back to the battery because of the distance.. you dont want a ground wire longer than 18inches (i prefer to keep mine under 12...) also going higher than 8 ga isnt neccissary as all you are doing is allowing more engery to pass through.. and the engine doesnt use that much.. for an amplifier for stereo you would need a bigger gauge wire..
Old Sep 20, 2003 | 11:31 AM
Unceasing Measure
Default Re: (Slammedciv96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammedciv96 &raquo;</TD></TR><TR><TD CLASS="quote">actually the battery is a good grounding point... energy moves in a cycle.. the battery isnt grounding to the frame the.. the frame is grounding to the battery... i can teach you basic electronics if you need... but in reference its not good to run back to the battery because of the distance.. you dont want a ground wire longer than 18inches (i prefer to keep mine under 12...) also going higher than 8 ga isnt neccissary as all you are doing is allowing more engery to pass through.. and the engine doesnt use that much.. for an amplifier for stereo you would need a bigger gauge wire.. </TD></TR></TABLE>
Exactly. I kept all my wires under about 20 inches and they're all 8 gauge. They're all neatly connected to a long bolt on the negative battery terminal. Works out fine.
Old Sep 20, 2003 | 01:59 PM
jordan88's Avatar
where did u mount the wires and where are the grounding point?
Old Sep 20, 2003 | 02:16 PM
Unceasing Measure
Default Re: (jordan88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jordan88 &raquo;</TD></TR><TR><TD CLASS="quote">where did u mount the wires and where are the grounding point?</TD></TR></TABLE>
Did you ******* read the thread you just started? Are you ******* retarded? Both of those questions were just answered in painfull detail.
Jesus Christ
Old Sep 20, 2003 | 11:29 PM
EK9Greg's Avatar
its alot cheaper to make your own ground kit. Use 8G wire And with a good ring clip on the end. Shrink wrap the ends to keep from any crosion. Depending on where you place the wires make sure they are hitting metal not paint. The cleaner the conection the better your off.
400whp
Mar 13, 2011 06:26 PM
type B16
Sep 5, 2006 08:18 PM
enhancedCL9
Feb 10, 2004 10:51 PM
THE94GSR
May 28, 2003 08:53 AM
