what can cause lean conditions in one cylinder?
Old Sep 18, 2003 | 05:33 PM
magic hat #9's Avatar
Default what can cause lean conditions in one cylinder?
i just pulled the plugs from my car. cylinders 1, 2, & 4 have nice, pretty plugs. cylinder 3's plug has an ugly coat of white. a month ago, i found cylinder 3's plug had a broken electrode; about half the electrode fell off and disappeared i checked the compression on the motor at that time and got 220psi across all 4.
what can cause one cylinder to run lean?
i think we can rule out the fuel filter because that would affect all cylinders. does this sound like a bad injector?
Old Sep 18, 2003 | 05:35 PM
Dan GSR's Avatar
Default Re: what can cause lean conditions in one cylinder? (magic hat #9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote"> does this sound like a bad injector?</TD></TR></TABLE>
thats what i was thinking.....have you tried taking the injector out....
I have some B16 injectors that you can have
Old Sep 18, 2003 | 05:48 PM
Default Re: what can cause lean conditions in one cylinder? (Dan GSR)
what do injectors cost at acura (i need it fast)? are they $140/each or $140/set of 4?
Old Sep 18, 2003 | 06:01 PM
ZygSpeed's Avatar
Sometimes people say that #3 runs hotter because of the firing order and the fact that cylinders 2 and 4 fire immediately before and after (I forget the firing order) keeping that cylinder hotter than the others.
At about 85 K miles I sent my stock injectors out to have them cleaned and balanced at RC Engineering, and upon return the spec sheet said that one of them was down to something like 184 cc/min whereas the other 3 were still performing pretty much as stock in the ~238 cc/min range (that one ylinder woud definately have been running leaner than the others). Ed
Old Sep 18, 2003 | 06:05 PM
dan, what's the difference between b16 injectors and b18c5? i would just go to acura and buy a new injector in the interests of motor health at the glen.
Old Sep 18, 2003 | 06:15 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">dan, what's the difference between b16 injectors and b18c5? i would just go to acura and buy a new injector in the interests of motor health at the glen.</TD></TR></TABLE>
I remember someone saying that all the B series motors use the same injectors ... so that might work.
Old Sep 18, 2003 | 06:26 PM
Tommy_Gunns's Avatar
Default Re: what can cause lean conditions in one cylinder? (zygspeed)
1-3-4-2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes people say that #3 runs hotter because of the firing order and the fact that cylinders 2 and 4 fire immediately before and after (I forget the firing order) </TD></TR></TABLE>
Old Sep 18, 2003 | 06:44 PM
uNF$@#!'s Avatar
Default Re: what can cause lean conditions in one cylinder? (Tommy_Gunns)
1-3-4-2, unless its zygs itr, in which case its 1-3-4-boom
Old Sep 18, 2003 | 06:49 PM
ZygSpeed's Avatar
Default Re: what can cause lean conditions in one cylinder? (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">1-3-4-2, unless its zygs itr, in which case its 1-3-4-boom </TD></TR></TABLE>
Are you coming to the Glen this weekend (mon/tues)?
haha ... because if you are I'll give you a ride in my car, you'll never forget (soil the car and your dead!)
Old Sep 18, 2003 | 06:59 PM
Christian's Avatar
I have a set of practically new OBDII ITR injectors
Old Sep 18, 2003 | 07:32 PM
Default Re: what can cause lean conditions in one cylinder? (Christian)
cool, bring 'em to the glen! what did the injectors cost?
if i swap in one of your injectors and plug is clean after a day of lapping, i would just buy a new injector (assuming you want to keep yours).
Old Sep 18, 2003 | 08:17 PM
visi0n's Avatar
last i recall Honda Fire Injector #3 First.
send your injectors out to be blueprinted for 5 dollars each i think it was.
Old Sep 18, 2003 | 08:18 PM
Christian's Avatar
I don't need the injectors.... make me a respectable offer and they are yours. The guy who traded with me had them in a 1999 ITR and he gave them to me when the car had less than 12k miles and just over a year old.
Old Sep 19, 2003 | 06:27 AM
KRiS1's Avatar
same thing in my itr motor
Ordered a set of RC 310's still waiting to put them in
Old Sep 19, 2003 | 08:23 AM
9redsi9's Avatar
# 3 almost always runs the leanest
LS/Vtec-F.T.W
Oct 5, 2010 12:49 AM
BoostR41
Engine Management and Tuning
Jul 18, 2009 06:28 PM
213374U
Mar 9, 2009 06:27 PM
96accordsir
Jul 7, 2008 08:36 PM
WhiteOnRice
15
Jun 4, 2008 06:29 AM
