TODA spec b cams help!
Old Sep 18, 2003 | 05:26 PM
TypRice's Avatar
Default TODA spec b cams help!
i am having a problem getting the car to idle right does any one have these cam that wouldnt mind helping a fellow R owner?
Old Sep 18, 2003 | 05:43 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: TODA spec b cams help! (TypRice)
What else do you have done besides the cams?
Toda B's = stock idle..... When tuned.
Old Sep 18, 2003 | 05:54 PM
NSX Bob's Avatar
New User
Default Re: TODA spec b cams help! (Splat)
More details required. If you have no type of engine management other than the stock ecu, then that's what you will have.
Old Sep 18, 2003 | 06:21 PM
StinkyTofu's Avatar
If you have nothing but a stock ecu, play around with your ignition timing until you can get it to idle. I wouldn't get on it until you tune it. If you have a vafc, lean it out 10 percent at idle. If thats not enough, go to 20. If thats not enough, keep trying to lean it out more. Give that a try.
Old Sep 18, 2003 | 07:00 PM
b19coupe's Avatar
I run 'D's in my Civic motor, and the idle is a tricky thing to tune even with Hondata. If you are on a stock or even a chipped ECU, you are going to have problems. Get some programmable engine management and get it tuned by a professional.
Old Sep 18, 2003 | 07:18 PM
Enrikez's Avatar
Default Re: TODA spec b cams help! (b19coupe)
lean out the idle with your fuel controller a bit..see if that helps. i dropped the fuel percetage about 10 percent at idle then played with the idle screw a bit....purrs like a kitten
Old Sep 18, 2003 | 07:41 PM
NSX Bob's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">I run 'D's in my Civic motor, and the idle is a tricky thing to tune even with Hondata. If you are on a stock or even a chipped ECU, you are going to have problems. Get some programmable engine management and get it tuned by a professional.</TD></TR></TABLE>
Correct me if I'm wrong, but don't D's have the same size primary lobes as the B's?
Old Sep 18, 2003 | 07:52 PM
b19coupe's Avatar
Default Re: TODA spec b cams help! (Type R Bob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type R Bob &raquo;</TD></TR><TR><TD CLASS="quote">
Correct me if I'm wrong, but don't D's have the same size primary lobes as the B's?</TD></TR></TABLE>
Exactly. That was my point. The idle tuning issues with 'B's are the same as 'D's. So all of the info is pertinent.
Old Sep 19, 2003 | 05:26 PM
TypRice's Avatar
i have the Toda spec B cams, toda cam gears, toda springs, skunk retainers, port and polish, mugen head gasket. Apex i VAFC, MSD.
The car wont hold a strong idle, i messed with the timing and i am at -26% on the vafc at idle!
if the cam gears are at zero and the timing is correct, how should the car Idle?
Thanks for everyones help!
Old Sep 19, 2003 | 06:21 PM
BlueR's Avatar
keep leaning it out @1000rpm, i'm at -30
Old Sep 19, 2003 | 06:26 PM
B2FiNiTY's Avatar
Default Re: TODA spec b cams help! (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">keep leaning it out @1000rpm, i'm at -30</TD></TR></TABLE>
Old Sep 19, 2003 | 07:02 PM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypRice &raquo;</TD></TR><TR><TD CLASS="quote">
cam gears at zero... car should idle damn near stock.
i suggest you ditch the VAFC and upgrade to a better form of fuel managment. VAFC gave me nothing but problems with my B's.... it was livable... but damn annoying. Take out at least -35 at 1000 RPM, and advance the intake cam. you may still other issues to deal with.
D
Old Sep 19, 2003 | 07:32 PM
BlueR's Avatar
Default Re: TODA spec b cams help! (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote"> you may still other issues to deal with.
D</TD></TR></TABLE>
like the damn car dying out when you come to red light
Old Sep 19, 2003 | 07:37 PM
MattD@Stoptech's Avatar
like the damn car dying out when you come to red light </TD></TR></TABLE>
You're supposed to press the clutch pedal, Marc
-Matt, whos just the whole day tinkering with the car and towing it to an exhaust place tomorrow so his ears wont bleed...
I need to get a shirt that says "I'd rather be driving"
Old Sep 19, 2003 | 09:37 PM
D's Avatar
D
yes.... with the VAFC i had a fine idle... however, when the motor was decelerating to idle, when it was hot out, it wouldn't catch the idle... as if the IACV wasn't acting fast enough. PowerFC has fixed said problem for myself.
D
Old Sep 19, 2003 | 09:46 PM
Black R's Avatar
25 Year Member
-50 here, and idle screw almost backed out all the way. 400 miles per tank and 190+whp. stock itr motor otherwise (with bolt ons). VAFC works for me.
Old Sep 20, 2003 | 04:26 AM
B18CXr's Avatar
What D said
Old Sep 20, 2003 | 04:52 PM
TypRice's Avatar
where is every ones cam timing at?
at zero the car should idle fine, with idle -30%(about)?
Old Sep 20, 2003 | 06:21 PM
Rob Dizzle's Avatar
did you have any other problems before you installed the cams?
Old Sep 20, 2003 | 08:32 PM
BlueR's Avatar
D</TD></TR></TABLE>
thats next on my lists when i put in the CTRs...
Old Oct 2, 2003 | 04:50 PM
TypRice's Avatar
Default Re: TODA spec b cams help! (Bob-DC2)
no other problems.... till the cams....anyway..
i got the idle right ...finally...timming was off...stupid me!
next ... the car feels weak till about 6000rpm...
now i need to know what to advance and what to retard?
i advanced the intake a bit and the car wouldnt start!
every things back to ZERO!
PY01ITR42
Feb 23, 2004 08:40 AM
EF_LSVtec
12
Jun 28, 2003 05:29 PM
TaboR
Apr 9, 2002 12:52 PM
1fastGSR
Dec 26, 2001 04:52 PM
amrintegra
Dec 9, 2001 12:18 PM
