CRX Hood Clearance
Old Sep 18, 2003 | 05:21 PM
Outkast_CL9's Avatar
Default CRX Hood Clearance
If you are running a 88-91 CRX with an engine swap other than a b16a...for instance a ls/vtec or gsr what kind of hood are you using. I have heard that there is a problem with swapping other motors into the CRX, other than a b16a, that has to do with clearance problems. I don't want the motor to sit to low to the ground which would leave no choice but to get a taller hood...will the SIR Conversion hood give me proper clearance?
Old Sep 18, 2003 | 06:19 PM
VTECVillain's Avatar
Default Re: CRX Hood Clearance (Outkast_EF8)
1991 CRX DX - HASport billet mounts, 1996 B18B1 Integra LS motor and 92 GSR YS1 cable tranny. I have no clearance issues with my stock hood which has not been grinded or modded in anyway and the motor isn't shimmed down either.
Old Sep 22, 2003 | 04:21 PM
Imadreamer1226's Avatar
I am using the hasport mounts and an lsvtec. the right side of my valve cover was hitting the lining under the hood. I ripped out all the lining and had to hammer just a wee dent along one of the cross-supports ( no idea what its called ) , and now it clears just fine. I hope that helps.
Old Sep 25, 2003 | 02:54 PM
93b18civic's Avatar
Default Re: CRX Hood Clearance (Imadreamer1226)
Imadreamer1226, man your avitar is the ****, cracks me up
TheCleanestRex
Jan 25, 2018 08:37 AM
Rob.
Jul 17, 2011 06:01 PM
B16Drag
Apr 25, 2010 07:14 AM
Outkast_CL9
15
Sep 20, 2003 11:13 AM
Spinin4
Jul 29, 2002 06:32 PM
