Anyone know about brake boosters and master cylinders?
Old Sep 18, 2003 | 05:03 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Anyone know about brake boosters and master cylinders?
Whats up fellas, I just converted my 97 LX stock braking system to one from an 01 GSR. I've been reading the other forums about boosters and MC's, and I am confused about one thing; since I'm running without ABS, does it matter if I get a MC and booster combo with or without ABS? Or will I have to find a combo that has no ABS at all? ANy help would be greatly appreciated, thanks
Old Sep 18, 2003 | 05:07 PM
Navid OG's Avatar
Default Re: Anyone know about brake boosters and master cylinders? (rukawa1one)
ok i have GSR brakes all around on my CX, im also non ABS, now to answer ur question YES, u must use a NON-ABS MC/BB (well the brake booster can be anyone u want, the MC is the one realted to ABS). i highly recomend u use an Integra RS MC/BB u can buy them together and they have braking power. I have also seen people use RS master cylinder with GSR brake booster, thats up to u. All u need to know is that u must use a NON-ABS Master Cylinder.
Good luck... and lemme know if u have more questions
Old Sep 18, 2003 | 05:16 PM
rukawa1one's Avatar
Default Re: Anyone know about brake boosters and master cylinders? (Navid OG)
hey thanks a lot for the help, any particular year i should go with?
Old Sep 18, 2003 | 05:18 PM
Quik Chris's Avatar
But why is that? I'm pretty sure I have an ABS GS-R MC in my VX, and I've been using it since April. I'm pretty sure (not completely) that the MC/Booster is the same regardless, it's just how the ABS system modifies the pressure in the lines.
Don't forget the 4040 proportioning valve which is oh-so-fun to install w/ a DOHC in the car.
Old Sep 18, 2003 | 05:25 PM
Navid OG's Avatar
not too sure about which year, mine all came from a 99 GSR but i bought the RS MC/BB brand new 2001, im sure they are mostly the same.
the reason from what i know is that the MC has a tube connecting to the ABS, since we don't have ABS that tube doesn't go anywhere and thus not compatible.
juba_x
Jan 21, 2011 09:51 PM
dustinbs144
Nov 10, 2010 05:27 PM
mxpx035
Jan 5, 2006 02:16 AM
zCivic
May 4, 2004 05:49 PM
