is it always necessary to hone the block when installing new piston rings?
i'm due for some new oil control rings, and was thinking of tackling it myself. If someone could answer my question as well as offer me any other input when changing the rings i would really appreciate it. thanks
ok that clears that up, but it brings me to my next question. Can the block be honed while mounted in the car, or does the shavings need to be cleaned out meaning the block must be entirely removed from the engine bay? thanks for the replies guys
cool guys thanks, yeah i am not gonna bother with milling the head or decking the block, right now it seals perfectly. the rings are my only concern ever since a little dyno mishap and since then i've been burning a slight amount of oil and have alittle more positive crankcase pressure than normal. Leakdown test also verified the rings in two cylinders, not that bad but bad enough to annoy me.
