Motor Mounts
Old Sep 18, 2003 | 11:15 AM
sohcvtec1995's Avatar
Default Motor Mounts
Can i use B16 motor mounts to put a 2000 gsr in a 95 civic ex coupe? I figured you could since this car was made with a b16. Or do i have to lay down the 450 dollars for a hasport mount kit? Or is there a combonation of different mounts thatt i can use? I already searched some and didi not find to much.
Old Sep 18, 2003 | 11:39 AM
Default Re: Motor Mounts (sohcvtec1995)
anyone?
Old Sep 18, 2003 | 11:43 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">Can i use B16 motor mounts to put a 2000 gsr in a 95 civic ex coupe? I figured you could since this car was made with a b16. Or do i have to lay down the 450 dollars for a hasport mount kit? Or is there a combonation of different mounts thatt i can use? I already searched some and didi not find to much.</TD></TR></TABLE>
What the hell are you talking about? The 1995 Civic EX wasn't made with a B16...it probably came with a D16Z6. As long as you have both the mounts from the engine and the chassis, you'll be able to combine them and get the engine installed with no problems. You don't need to buy any kind of mount kit to put a B-series in an EH chassis car.
Old Sep 18, 2003 | 12:52 PM
dj_seloe's Avatar
Default Re: Motor Mounts (Archidictus)
therrrrr yooo go!
Old Sep 18, 2003 | 01:24 PM
97civicdx's Avatar
Dont you use the GSR brackets and the civic mounts?
Old Sep 18, 2003 | 03:55 PM
Default Re: Motor Mounts (97civicdx)
i was reffering to the EG sir's with the b16. it is the same front end there buddy.
Old Sep 18, 2003 | 04:02 PM
97civicdx's Avatar
So use the b-16 brackets and civic mounts. Buddy...........
But your question was a 2000 GSR into the EG civic platform
http://tech.hybridgarage.com/t...g.htm
Old Sep 18, 2003 | 05:00 PM
Newman's Avatar
New User
EG and DC chassis is the same (engine bay wise) so you can use all of the Integra mounts & brackets for the swap. You can also use the EG6/9 B16 mounts and brackets also, but the 94+ Integra driver side bracket & mount is different from the B16 driver side bracket and mount so that would need to be changed out. But otherwise, all the same elsewhere. Use either linkage (JDM B16A EG6/9 or 94+ Integra).
Old Sep 22, 2003 | 10:44 PM
johnny5sTypeR's Avatar
Talk to Uriah, they have good motor mounts
crxpwr1
26
May 28, 2006 12:41 PM
rdawg000
Dec 6, 2004 04:24 PM
rdawg000
Dec 6, 2004 03:54 PM
dub204
Jun 8, 2004 10:17 AM
td04civic
May 7, 2002 04:56 PM
