What is a good all motor street set up?
Old Sep 18, 2003 | 05:05 AM
SupaFly_Honda's Avatar
Default What is a good all motor street set up?
I'm in the process of building my b16 for street use and reliability. I'm looking to put in about $1500 worth into it without major machining work. Give me some ideas or list of items that you guys would recommend. thanks
Old Sep 18, 2003 | 05:17 AM
JaeOne3345's Avatar
Default Re: What is a good all motor street set up? (SupaFly_Honda)
Why dont you do some researching in the all motor forum.
Old Sep 18, 2003 | 05:19 AM
JICEK9's Avatar
attack the head! get a nice set of skunk2 cams, valves, retainers. do a different head gasket, and get some hondata! pretty easy to do in your garage.
Old Sep 18, 2003 | 05:39 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: What is a good all motor street set up? (JaeOne3345)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you do some researching in the all motor forum.</TD></TR></TABLE>
I just moved it into the All Motor forum.
Old Sep 18, 2003 | 05:53 AM
rodimus's Avatar
Default Re: What is a good all motor street set up? (B18C5-EH2)
is it a b16a or b16b block?
if it's a b16b i would put a type r crank, rods
and pistons of your choice in there
Old Sep 18, 2003 | 06:09 AM
Cashflo's Avatar
Default Re: What is a good all motor street set up? (JICEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 &raquo;</TD></TR><TR><TD CLASS="quote">attack the head! get a nice set of skunk2 cams, valves, retainers. do a different head gasket, and get some hondata! pretty easy to do in your garage.</TD></TR></TABLE>
I agree with this guy, "attack the head!" Talk to Luckyracing( i think thats his sn). I remember back in 95-96 my friends were getting some kick *** head packages for cheap. Back then luckyracing was associated with PYR, dont know if they still are today, but I see some good time slips associated with luckyracing allmotor wise.
Old Sep 18, 2003 | 06:23 AM
no2psi's Avatar
Buy a b20 bottom end. Mill your head slightly put in some type r cams and you will get around 180 to 190 whp and more torque than any b16. It can be done for a little more than 1500 assuming you do all the work your self. I just finished one and it rips.
Old Sep 18, 2003 | 09:28 AM
B3AS's Avatar
there you go
Old Sep 18, 2003 | 09:43 AM
Drag R's Avatar
Default Re: What is a good all motor street set up? (Love2race)
anything over 14:1 should be fine :
Old Sep 18, 2003 | 11:30 AM
Default Re: What is a good all motor street set up? (Drag R)
I did some research and reading and I finally got my list together. Something small but affordable($2k) ...let me know what ya think?
...skunk2 stage 2 cams, retainers, valves and valve springs with skunk manifold
...civic type R pistons and rings and new head gaskets
...and hondata for the brain.
Old Sep 18, 2003 | 11:35 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupaFly_Honda &raquo;</TD></TR><TR><TD CLASS="quote">I did some research and reading and I finally got my list together. Something small but affordable($2k) ...let me know what ya think?
...and hondata for the brain.</TD></TR></TABLE>
very nice setup. good luck with it and please keep us updated!
Old Sep 18, 2003 | 08:37 PM
12secB18acivic's Avatar
Hmmm...no machine work......Here's what i would get:
Dtr header:$1000
Ctr pistons : $350
CTR cams : $300-400
Skunk manifold or type r: $200-250
chipped p28 : $150-200
These are very easy items to get. although your setup seem pretty nice too. Good luck
Old Sep 18, 2003 | 09:42 PM
B18G's Avatar
CTR pistons...
Isn't that a little high for pump gas?
I'd go PR3 ... save a tiny bit of cash
Old Sep 18, 2003 | 10:35 PM
Cashflo's Avatar
Default Re: (B18G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18G &raquo;</TD></TR><TR><TD CLASS="quote">CTR pistons...
I'd go PR3 ... save a tiny bit of cash</TD></TR></TABLE>
remember the ctr pistons are going in a 1.6, which is still good for pump gas
Old Sep 23, 2003 | 04:39 AM
Default Re: (eghead)
hey I'm just curious if any of you guys know how much hp this setup will get me? no tunning.
also, is a oem honda head gasket okay with this set up?
Old Sep 23, 2003 | 05:00 PM
LUCKYMIKE's Avatar
use that b16 bottom end as a boat anchor and get an ls bottom end with a nice set of pistons with 1500 u could even get some cams and valvetrain for the b16 head
Old Sep 23, 2003 | 08:37 PM
FLOWZILLA's Avatar
attacking the head is your best bet a nice port job ,springs ,retainers, valves ,a good valve job, some chamber , rs machines have a nice set of cams you should try giving them a call thier number is 310-328-5514 . the head is the best way to make nice reliable power
Old Sep 24, 2003 | 12:36 AM
Cashflo's Avatar
Default Re: What is a good all motor street set up? (punkonnos)
just to let you know AEBS designed a new intake manifold (typhoon intake manifold) that does 20hp more than a type-r intake manifold. It actually shifts 20hp throughout the powerband . Ill get dyno sheets up. I was quoted $160.
nogi
Honda Civic (2001 - 2005)
Sep 29, 2007 05:06 AM
94vtirozguy
May 15, 2007 06:38 PM
jdmsijdm
Feb 24, 2006 06:10 AM
advanracing62
Sep 8, 2003 11:10 AM
specie
Jun 12, 2003 10:08 AM
