any ideas on this?
Old Sep 17, 2003 | 10:05 PM
meccA's eg6's Avatar
Default any ideas on this?
when my 92 dx got jacked the guy cut the o2 sensor but left the sensor in the car...so i crimped all the wires together cept for the big white one..i pulled the metal shield back and just connected the wires, my check engine was gone and gone for a while. but now like when i get on it and say redline 2nd into 3rd, mid to high 3rd the check throws again, but resets and is gone if i start the car right after?...any ideas, is it becuase that sheild is not connected or is it something else?
Old Sep 17, 2003 | 10:40 PM
nwdave's Avatar
Default Re: any ideas on this? (meccA's eg6)
Did you check and see if it was still wired up?
Something might've shaken loose.
Old Sep 17, 2003 | 11:48 PM
Default Re: any ideas on this? (delsolguy)
yea its still all connected
Old Sep 18, 2003 | 05:24 AM
JICEK9's Avatar
somebody please correct me if i am wrong but... i dont think those wires are meant to be cut and once they are i dont believe the o2 is any good.
Old Sep 18, 2003 | 05:39 AM
dwnthehatch's Avatar
Default Re: any ideas on this? (JICEK9)
Try soldering the wires.
Old Sep 18, 2003 | 08:51 AM
the o2 still has to work or the check would throw from start up, it only throws when i get on it, im not sure if its that or something else?
Old Sep 18, 2003 | 10:04 AM
allmotorEG-SI's Avatar
try checking your codes. I may be wrong, but I think you can still have codes in your ECU even without a check engine light on.
Old Sep 18, 2003 | 12:52 PM
Default Re: any ideas on this? (allmotorEG-SI)
alright i'll try to check it and find out which code...
Old Sep 18, 2003 | 01:13 PM
-Trinitron-'s Avatar
Your sensor might be going bad. Because once you throw a code, it should stay on until you either fix the problem, or reset the ECU.
Old Sep 18, 2003 | 02:20 PM
4DRPIMPIN's Avatar
yeah check to see what code it is.
jimdamico
Honda Civic (2001 - 2005)
Apr 12, 2019 09:58 AM
S2KILLA
Jul 7, 2010 08:30 AM
thanh4o8
Sep 21, 2009 11:47 PM
93civciv
Jan 6, 2006 11:03 PM
runitup
May 2, 2004 10:02 PM
