Recommendations for shop to do clutch and LSD?
Well its time to replace the stock clutch after 2 years of being boosted (also decided to drop in a lsd while the transmission is out) and wondered if anyone knew any good shops around the socal area to install a type-r lsd and Action clutch. Looking for somewhere that won't charge an arm and a leg. Thanks.
dynamic autosports, erick's racing. it will cost a bit though because the labor involved. might as well change your flywheel out while youre at it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrew 825SM »</TD></TR><TR><TD CLASS="quote">Well its time to replace the stock clutch after 2 years of being boosted (also decided to drop in a lsd while the transmission is out) and wondered if anyone knew any good shops around the socal area to install a type-r lsd and Action clutch. Looking for somewhere that won't charge an arm and a leg. Thanks.
that's the same setup that i installed in my car. action stage 1 with a segmented kevlar and an itr lsd. give PRIZM Performance a call (310) 787-1562 and ask for KEVIN. His prices are a little steep, but he works meticulously.
he's located in torrance
