Does N e one No where is the main relay on the 92 Hatchback civics.
If you are sitting in the driver's seat, it is directly above the dead-pedel. It is a small grey box mounted by a bracket with one bolt. Has like a 20 pin connector in it.
HTH,
-Nick-
HTH,
-Nick-
is your car dying on you?? if so.. instead of spending $50 on a new main relay, u might just want to resolder the connection on your existing one. works the same.. and saves u money
My car died on me while i was driving and now it doesnt want to start.I started it again on saturday for a minute and shut it off just to see if it would start.Monday i installed some dsm injectors and resistor box and then it didnt want to start.The car is getting spark,fuel pump is priming and there is pressure in my fuel rail.Just wondering if this could cause this to happen.
Well if you need a main relay I have a spare I can hook you up with for a good price cause it's just sitting in my tool box.
I found out my injectors arent getting power.I used a tester and a volt meter and its not showing any signs of power.Anyone know how to open up the relay and what am i looking for if its broke?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">My car died on me while i was driving and now it doesnt want to start.I started it again on saturday for a minute and shut it off just to see if it would start.Monday i installed some dsm injectors and resistor box and then it didnt want to start.The car is getting spark,fuel pump is priming and there is pressure in my fuel rail.Just wondering if this could cause this to happen.</TD></TR></TABLE>
If the car is getting spark, and the fuel pump is priming, then the Main Relay is GOOD.
The CEL comes on and goes off after two seconds with the key in the ON position correct?
Sounds like you possibly wired up the injectors incorrectly or the resistor box is bad.
How exactly did you wire up the resistor box?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">I found out my injectors arent getting power.I used a tester and a volt meter and its not showing any signs of power.Anyone know how to open up the relay and what am i looking for if its broke?</TD></TR></TABLE>
The main relay is fine!
Sounds like you hooked up the resistor box wrong.
What colors are on the resistor box? 4 black and 1 red?
D7KWagon
Aug 5, 2014 01:57 PM
rasinhell
Mar 7, 2005 06:09 AM
to Smooch Pickle
