funny noise under hood
what up h/t...quick question...when i start my car, i hear a funny noise coming from the upper left corner of the engine by the abs system thingy...it sounds like something is vibrating VERY LOUDLY...what the hell is it b/c it's annoying...thanx in advance peps...
-scott
-scott
Normal ABS system noise....pump is pressurizing the system. It should only last about 3 seconds or so. If it lasts any longer, it is low on fluid, or there is a leak in the modulator---very expensive. If you brake to the point that the ABS engages, you will briefly hear the noise again after you stop.
