Worth it to go from....
Old Sep 17, 2003 | 07:52 PM
B19CivicHB's Avatar
Default Worth it to go from....
Stock GSR cams to Type R cams...
Right now Im running stock GSR cams in my B18C1 with 12.7:1 CR as I cant afford a good set of cams yet. Engine is fully NA built, sans cams. I have the opportunity to trade for a set of Type R cams.
Ive never thought of the small step up, but high compression loves cams. I would assume that even as relatively mild as the R cams are, that it would be a magnified increase in power due to the high compression.
Can anyone add to my speculation??
Thanks fellas,
-Nick-
Old Sep 17, 2003 | 09:01 PM
T4eg's Avatar
Default Re: Worth it to go from.... (B19CivicHB)
I would get the ITR cams. It couldnt hurt nothing IMO
Old Sep 17, 2003 | 09:03 PM
Audi RS4's Avatar
Lover
I think you would be very pleased with the results if you went with ITR cams. i'm might be mistaken but wouldn't it be a drivability issue to run with ITR cams at that compression? anyone????
Old Sep 17, 2003 | 09:28 PM
B19CivicHB's Avatar
Default Re: Worth it to go from.... (AK1200)
Ive had a bit of trouble getting it to run with out minor pinging or major detonation. Right now ignition timing is set a 16 degrees BTDC and it runs well. Im getting a Mugen chipped ecu with the R cams and I plan on retarding the timing another 2 degrees to help prevent any detonation.
Thanks for the input. Cant wait to throw them in !
-Nick-
Old Sep 18, 2003 | 06:39 AM
whitelightning's Avatar
i've got 00 itr cams and love them...i'd say its worth it
g23cg5
Nov 15, 2013 04:58 AM
Easyslider01
Oct 7, 2006 04:23 PM
tomlinson619
May 22, 2006 07:59 PM
DA-9mordef
Apr 27, 2006 10:04 AM
Junglist
Jan 3, 2003 08:59 PM
