car won't start on first try
Old Sep 17, 2003 | 07:34 PM
PA MATT's Avatar
Default car won't start on first try
i searched guys, but couldn't find anything that applies....my situation is sometimes when i go to start my car...it wont turn over. if i turn the key to the off position and then crank it again, it'll turn over and run fine. sometimes,however, after turning over itll stall back out. any idea what this could be or how i could diagnose the problem?thanks in advance for any help
Old Sep 17, 2003 | 09:02 PM
T4eg's Avatar
Default Re: car won't start on first try (ebpG2)
faulty ignition switch would be my guess. Because it works sometimes and sometimes it dont
Old Sep 17, 2003 | 09:35 PM
Noe Kozz's Avatar
Default Re: car won't start on first try (BlueHatch00)
check your alternator.......or distributor.
Old Sep 17, 2003 | 10:25 PM
BuddhaSiR's Avatar
Default Re: car won't start on first try (Noe Kozz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noe Kozz &raquo;</TD></TR><TR><TD CLASS="quote">check your alternator.......or distributor.</TD></TR></TABLE>
wut do those items have anything to do with his motor not turning over?
check for a loose connection at the battery or at the starter.
Old Sep 18, 2003 | 02:44 PM
PA MATT's Avatar
Default Re: car won't start on first try (BuddhaSiR)
thanks guys
Old Sep 18, 2003 | 03:53 PM
jrfinfrock's Avatar
sounds like a starter solonoid
Old Sep 18, 2003 | 04:47 PM
BeerMan's Avatar
Default Re: car won't start on first try (jrfinfrock)
It most definately could be a distributor problem (though, it is probably something else); a bad bearing has those symptoms.
Old Sep 18, 2003 | 09:30 PM
Stripped Honda's Avatar
99-0104
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrfinfrock &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a starter solonoid</TD></TR></TABLE>
nice GUESS but no that couldnt be the problem
i would also say that it is the ignition switch it is a common problem for people who have alot of keys on their key ring
Old Sep 19, 2003 | 04:58 AM
fathergoose's Avatar
check your grounds
IGuess
Nov 1, 2009 07:41 PM
Scud
16
Jan 18, 2008 03:15 PM
smokez187
Aug 10, 2007 11:35 AM
shorbie621
27
Jun 2, 2006 10:08 AM
Eggman
Nov 22, 2001 11:51 PM
