Why do big cams benifit from higher compression?
Old Aug 22, 2001 | 11:55 AM
HX_Guy's Avatar
Default Why do big cams benifit from higher compression?
I have heard it said in the past that big cams love high compression - and that when the compression is raised on an engine with big cams...the power is really much more noticable (then stock cams w/ high compression)
Why is this?
Old Aug 22, 2001 | 12:00 PM
sgT's Avatar
sgT
Default Re: Why do big cams benifit from higher compression? (HX_Guy)
Due to the high overlap, a lot of air can get out before the valves close and
the piston compresses the mixture. higher compression can help make up for
that
Old Aug 22, 2001 | 02:00 PM
DB2-R81's Avatar
25 Year Member
Default Re: Why do big cams benifit from higher compression? (sgT)
Like Steve said longer duration results in lower dynamic compression so your really just making up for your losses from static compression.
integra123
May 10, 2006 01:05 PM
fsp31
11
Jun 7, 2005 05:18 AM
silversly
Dec 18, 2004 08:02 AM
Dan GSR
Aug 27, 2004 07:15 PM
Modifiedinteg
Oct 29, 2003 06:46 AM
