Carbon hood
Old Sep 17, 2003 | 04:57 PM
90crxb16a's Avatar
Default Carbon hood
Fixin to order a Vader style hood from carbon creations. Comes to a total of 550 or so. Was wondering if anyone knows a cheaper place to get the vader style that has the same quality and carboncreations. Or if there is a Group buy going on
Old Sep 17, 2003 | 05:13 PM
guttedEF's Avatar
Default Re: Carbon hood (90crxb16a)
Maybe I'm a moron.. but what exactly is a "Vader style"?
Old Sep 17, 2003 | 05:16 PM
90crxb16a's Avatar
A Style of hood
http://www.carbon-creations.co...Hoods
Old Sep 17, 2003 | 06:23 PM
Spork Sports's Avatar
Default Re: (90crxb16a)
Isn't that the same as VIS Invader hoods? If so, you can get the VIS for about $350 shipped every now and then in a group buy.
Old Sep 17, 2003 | 07:24 PM
VAAJ's Avatar
Default Re: (Sew Fast)
are there any problem of clearance with these vader style hood in an ef with a b16???
Old Sep 17, 2003 | 07:27 PM
redhatchb18's Avatar
Default Re: (drift2live)
man my boy has a zc type carbon hood and he has clerance probs with his b16 on his rex so you might want to really check that.
Old Sep 17, 2003 | 08:54 PM
LoooseGSR's Avatar
Default Re: (babyboib16)
it also depends on what mount kit you're using.
Old Sep 17, 2003 | 09:08 PM
VAAJ's Avatar
Default Re: (PSUCRX)
hasport mounts
Old Sep 17, 2003 | 09:18 PM
LoooseGSR's Avatar
you should be fine, out of the 3 major mount brands, only one will still give you problems...I think.
Old Sep 17, 2003 | 09:40 PM
Starbucks_91b16acrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by babyboib16 &raquo;</TD></TR><TR><TD CLASS="quote">man my boy has a zc type carbon hood and he has clerance probs with his b16 on his rex so you might want to really check that.</TD></TR></TABLE>
i have a vis zc cf hood and i got mine for 290... its a real high qaulity hood... i also have plenty of clearance with my b16.
i have place racing mounts
Old Sep 17, 2003 | 09:49 PM
LoooseGSR's Avatar
Default Re: (91b16aCRX)
where did you get your hood...i'm in need of a cf hood.
Old Sep 18, 2003 | 02:53 AM
slywfbpsi's Avatar
VIS told me that the invader hood would not clear the bseries motor in an ef.
Old Sep 18, 2003 | 04:10 AM
rjardy's Avatar
Default Re: (slywfbpsi)
Do all these carbon hoods have at least as much room as the stock hood? my swap and turbo and everything fits under the stock hood fine. I want a CF hood but need at least as much room as I have now, my wastegate is close.
Rob
Old Sep 18, 2003 | 05:15 AM
slywfbpsi's Avatar
Default Re: (rjardy)
the thing about the invader hood is that it goes down further than the stock hood's indent so with a bseries engine you run the risk of hitting the valvecover/wastegate/exhaust manifold. When I had one on my 00si, it looked like it would clear the exhaust manifold, but I may have needed to get a 90 degree elbow for the wastergate, this was if I was going to use a log style manifold, if I was going to run a equal lenth tubular then I would have had hood clearance issues. If I was going to get a cf hood in my ef, I would at least get a sir style cf hood for the usdm cars from fiber images because the zc hood will only help with the cam gears, but what about the wastegate and manifold issues?
Old Sep 18, 2003 | 06:44 AM
manson's Avatar
good luck getting a hood from fiber images...
Old Sep 18, 2003 | 07:09 AM
Lo-Buck EF's Avatar
Default Re: (mansonclubpuir)
http://www.asylumms.com/00web/...t.htm
Old Sep 18, 2003 | 10:16 AM
slywfbpsi's Avatar
Default Re: (Lo-Buck EF)
I don't see a fiber images hood on that site, but I see one at http://www.mmrusa.com/fiberimages.htm
Old Sep 18, 2003 | 01:03 PM
stockcrix1616's Avatar
be carefull if you get one with the vents in it. i had an old friend that had that style of hood and every time it rained he would get water all in his plug holes and the water on his hot motor and exhaust caused the header to crack and rust up.
Old Sep 18, 2003 | 04:29 PM
90crxb16a's Avatar
Im planning on getting one from Carbon-creations. Not fiber images if that makes a difference.
I have hasport mounts.
If it wont fit , then what carbon hoods will fit?
Thanks for the info
Old Sep 18, 2003 | 06:32 PM
slywfbpsi's Avatar
Default Re: (stockcrix1616)
with my invader hood I had steam coming through the vents when I washed the car or when it was raining and I was at a stop light, but since I had a spark plug cover, and heat shield, my plugs never got water in them, and my header didn't rust or crack
crxb16a - like I said in my earlier post you could get a fiber images sir style hood for the usdm front end, or the zc hood from vis, but the sir h cf hood for the usdm from end from fiber images, will only be the sure fire way of not having to worry about the valve cover/wastegate/exhaist manifold from hitting .
Old Sep 21, 2003 | 04:37 PM
90crxb16a's Avatar
Old Sep 25, 2003 | 11:12 AM
get the vis zc cf hood
Old Oct 3, 2003 | 06:52 PM
VAAJ's Avatar
where could a get a vis zc cf hood? any place that has a good pricing.
Old Oct 5, 2003 | 09:15 AM
autolinks in temple city
Old Oct 6, 2003 | 09:41 PM
VAAJ's Avatar
do they have a website?
