DRL kits.....
Does anyone make them?? I'd like to get one if possible. Reason is this...I drive a lot w/ my daughter, and ANYTHING that helps me be seen will be good.
if you remember to turn them off, you can hook up a good set of PIAAs to your parking light "ON" wire and do that. that's what i did, but my alarm also has an auto on headlight feature with a light sensor.
O.k. well what you can do is get the accord oem running lamps and there are a couple of ways to set them up that is one of the ways in the instructions.If you go with them and have a problem wiring them hit me up I will help.
are you referring to the oem FOG lights? if so, i'm trying to score a set of barely used ones for $100......no oem switch though.......that's no big deal.
i just "might" get cheapo driving lights or something from pep boys for this purpose...if i can't find a true DRL kit...
